Wayne2015
White VR6 in Windy Yorkshire! :)
The protruding bit (bottom middle of glove box)
My glove box wasnt shutting properly (lock not stating in lock position)
So took glove box door apart
Take hinge out either side of door bottom
Nothing to take apart/clean really :shrug:
Re-assembled
And the door now closes and locks perfect! :thumbleft:
Guess it just needed re-aligning??? :shrug:
Putting glove box back in a little easier ...
As u can see the protruding part and FORCE it over the metal frame ...
I find it easier to remove glove box if u remove the trim/storage panel under it ...
Passenger dash speaker + vent grilles ...
Pull out grille
x2 screws bottom
x1 screw top
If u have no specialist tool s to remove screws in tight spots
Then like me use screwdriver bit and turn by pliers! :lol:
Bottom
Top
Just pull out vent housing from inside/back
Reveals my dash speakers NOT connected! :eek:
If u have removed the glove box
Then u can see the dash speaker wires are
Dash speakers grilles
Remove by pulling off
Speakers just pushes tightly onto back of grille
Window vents (pull off)
Look at the debris!
Centre dash vents (just pull out)
Driver dash speaker + vent grilles + speedo surround ...
Pull out dash vent and just x1 screw top
x2 screws bottom speedo surround
(In my case x1 screw and BLUE TACK :eek: )
x2 screws top
Pull out and remove
Push out cover (in my case alarm LED)
Same with headlight switch
Pull out dash vent housing (from back/inside)
Remove dash speakers + window vent (as u did on passenger side)
My window vent :shocked!:
Think
As this stage i went a bit crazy
And started to remove anything and everything!!! :eek:
Storage under steering column
:lol:
:dance:
Edited by Wayne2015
I've got some screws for the seat handle, if you need them.
Yes I do!
Thanks Sanky! :clap:
Thanks to Sanky :clap:
Allen screws too (so easier to screw to seat :) )
Do you take your camera to the toilet Wayne?
Nah man
There s CCTV in the loo already ;)
When you're a high security patient .... It's only to be expected.. lol
:lol:
Still waiting for my pot of Earl Grey, mate!
Haven't bought it yet.... Will let you know when i get it in. And you're welcome to come have a cuppa.
Keep the pot warm for me!
:thumbleft:
Aye yeah
Forgot u said u were one of these (hence special) :lol:
Chuggs
U learnt much on the Corrado then?
As I believe we were pretty much very very novices to the Corrado and car maintenance in general ?
Not as much as you mate. But so far Been lucky and not had too. Just keeping it clean. The only issues i had was electrical and caused by the New alarm being fitted. So they did the repair for free. Other that that had brakes done and I wasn't messing with that. Sure I won't remain that lucky but for now just enjoying.
Cool
As long as u happy :)
Yeah
I learnt so much these couple of months
And not just the Corrado - but car maintenance in general :thumbleft:
It makes me think
Yeah - i prefer reliable cars and nothing much needs fixing.
But having a car (as long as its a 2nd car) to tinker with - its great to get stuck in! :dance:
Thanks to Chris (lilfuzzer) for supplying my missing screw caps :o
Before
After
Putting back the storage panel under the glove box ...
Anyone know what clips/screw caps /cover for this fixture (to secure the storage panel to floor)???
