Do you know what size the standard rear discs are in mm so i can measure them up?
229mm from memory
Ok so just before i order discs and pads can i clarify...(assuming the car has mk4 rear calipers) i can getstandard vr6 discs 226mm with bearings etc i see pagid do a kit, and golf mk4 pads being 17.2mm (rather than vr6 pads at 15.5mm) sorry guys im just getting used to these things!! You have been great so far!
You'll need a calliper wind back tool too if you don't have one?
http://www.ebay.co.uk/itm/UNIVERSAL-NEW-BRAKE-CALIPER-PISTON-REWIND-WIND-BACK-TOOL-KIT-22-34-PIECES-SET-/360643337387?pt=LH_DefaultDomain_3&hash=item53f8049cab
I've used the above on MK4, Corrado and T5 so far and its worked well - you may find the same kit cheaper if you search ebay
I've got with the 15mm corrado pads. Think i had the thicker ones last time and something wasn't right. Someone else fitted them for me so i don't really know what was up
