fla 9 Posted May 30, 2015 Moving on to the aesthetics now. Anyone running tt comps? If so which centre caps fit the rear wheels with the protruding dust caps? Been looking through ebay but can't work out what to get. The cap id looks to be 56mm Quote Share this post Link to post Share on other sites
borachris 0 Posted May 30, 2015 I had the same problem with my Montreal 2's, tried a few different caps, genuine and cheap copies, non of them would fit. Only idea I came up with was to run a spacer on the rears! Quote Share this post Link to post Share on other sites
fla 9 Posted May 30, 2015 Thanks chris. The problem is that spacers will make the tyres rub the arches. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted June 1, 2015 Try looking on the VR6OC, as I did use a set on my mk3 VR to clear the dust cap issue when I had the TT comps fitted. Just cant find the part number, for you. Quote Share this post Link to post Share on other sites
fla 9 Posted June 1, 2015 sanky - are you referring to spacers or types of dust caps that fit? My dust caps are tight on the stub axle thread so dont want to be tapped in! Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted June 1, 2015 I referring to the centre caps. I had a set of VW ones that were domed outwards, which helped clear the dust cap issue on the rear discs. Quote Share this post Link to post Share on other sites
fla 9 Posted June 1, 2015 ok thanks. I was hoping to fit audi centre caps in silver or chrome just to maintain continuity; most of the vw ones seem to be black and chrome Quote Share this post Link to post Share on other sites
