EJ Taylor 22 Posted June 2, 2015 mines split, but a little K & N filter came with my SC kit few years back to replace it, i was deterred by oil splatting all over my bay? has anyone got any experience of this? Or is it one of those, dont really matter things Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 EJ - you can buy the PCV valve itself from Ford & they are nice & cheap IIRC - one of the galaxy's uses the same part dont go to VW as they try to sell you pretty much the entire air intake section Quote Share this post Link to post Share on other sites
rickdonald 10 Posted June 2, 2015 I had the same on my old VR and ended up trying to epoxy it back together as I couldn't find another. When I bought my G60 it had the K&N filters on the crank breather and the ISV, and the engine bay was covered in oil! I mean COVERED! It was good because it meant nothing under my bonnet was rusty.......but not so nice when you needed to do work on it. I ended up re-instating all the standard pipework and spent about a week de-greasing and pressure washing the engine, gearbox, firewall, heat shields and all the wiring looms. I'm not sure how similar it would be on the VR, wouldn't imagine its too bad as long as you clean it regularly. Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted June 2, 2015 its just split where the house meets the rubber disc valve exterior so i think just the part. Dont suppose you know a link? or where/ what i need to ask for? Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted June 2, 2015 I had the same on my old VR and ended up trying to epoxy it back together as I couldn't find another. When I bought my G60 it had the K&N filters on the crank breather and the ISV, and the engine bay was covered in oil! I mean COVERED! It was good because it meant nothing under my bonnet was rusty.......but not so nice when you needed to do work on it. I ended up re-instating all the standard pipework and spent about a week de-greasing and pressure washing the engine, gearbox, firewall, heat shields and all the wiring looms. I'm not sure how similar it would be on the VR, wouldn't imagine its too bad as long as you clean it regularly. good feedback thanks man, very helpful! Quote Share this post Link to post Share on other sites
fla 9 Posted June 2, 2015 You could install an oil catch can. Get some stainless steel wool and put that in the can to increase surface area To help condense the oil vapours. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 its just split where the house meets the rubber disc valve exterior so i think just the part. Dont suppose you know a link? or where/ what i need to ask for? let me check my build thread EJ, i might have put it in there Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 let me check my build thread EJ, i might have put it in there ha ha i thought i did "looking at the ford invoice it shows 7364573 & was £32.50+vat" there you go EJ :) may as well replace it with the correct part rather than a bodge or a fix which will cause you more work IE cleaning Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted June 2, 2015 You could install an oil catch can. Get some stainless steel wool and put that in the can to increase surface area To help condense the oil vapours. nice man, have to look into this! ha ha i thought i did "looking at the ford invoice it shows 7364573 & was £32.50+vat" there you go EJ :) may as well replace it with the correct part rather than a bodge or a fix which will cause you more work IE cleaning Absolute legend thanks mate!!!! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 2, 2015 I've ditched mine and fitted a 42Draft or Draft42 oil catch can. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 Absolute legend thanks mate!!!! my pleasure m8 :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 I've ditched mine and fitted a 42Draft or Draft42 oil catch can. sounds posh Jim - are they shiney? lol & how costly? Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted June 2, 2015 sounds posh Jim - are they shiney? lol & how costly? yer im tempted now tbh, guna scope the bay later and see where one might look nice Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 2, 2015 I got mine 2nd hand off the forum so was cheaper than normal, and its the stealth one in a black crinkle finish so not shiny. Makes it look like i'm a serious engine tuner though so i like it :lol: Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 I got mine 2nd hand off the forum so was cheaper than normal, and its the stealth one in a black crinkle finish so not shiny. Makes it look like i'm a serious engine tuner though so i like it :lol: can we have a picture pls Jim if possible? :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 2, 2015 Shows up in these pics, i haven't fitted engine to car yet though. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 cool thanks Jim if it is a catch can does that imply you have to periodically empty it? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 2, 2015 Yeah, it does have a drain screw at the bottom Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 2, 2015 Yeah, it does have a drain screw at the bottom cool thanks for your feedback Jim Quote Share this post Link to post Share on other sites
