Reverend Frog 10 Posted July 8, 2015 had a look under my bonnet and noticed this pool of water behind the bulkhead, near the wiper motor. am i right in thinking that there is something missing here? and does this pose a problem if water collects here? [ATTACH=CONFIG]81979[/ATTACH] Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 8, 2015 Probably a drain has become blocked around there mate. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted July 8, 2015 as jon says there is a drain hole there the rain cover only covers the heater motor Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted July 9, 2015 As has been said already there is a drain hole there and one on the other side as well. They drain out behind the arch liners, make sure both a clear. Clean them out before it starts rotting the car. Quote Share this post Link to post Share on other sites
Yandards 0 Posted July 9, 2015 You can fit a B3 Passat wiper motor cover which tidies the area up and a MK 2 Golf scuttle cover will also go with the aid of some heat to adjust the moulding slightly - hair dryer will do it. Quote Share this post Link to post Share on other sites
