rjp.henderson 10 Posted July 10, 2015 Does anyone know when if ever the spoiler in my G60 self raises? Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 10, 2015 Yes it does raise itself . Mine raises at 50 mph , others will raise at 45 mph . You can change the settings . If yours is not raising , which I guess is the reason for your post , I would check the fuse . If this is fine , then you will have to give the motor contacts and the movements a good clean . Failing that if it does not work a new motor might be required . Quote Share this post Link to post Share on other sites
Yandards 0 Posted July 11, 2015 Duplicate thread removed, please keep questions about the same thing in one thread only. If it raises on its own via the manual switch then you can rule out the spoiler mechanism, it may then be a faulty controller (located inside the dash near the switch) or a the hall sender on the gauges is broken which is where it gets the speed signal from. Quote Share this post Link to post Share on other sites
