deano46 10 Posted July 22, 2015 Fan runs during and after engine. And the pump definitely runs because I can hear it whining (loudly). Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 22, 2015 Might be a bit sticky am sure you can clean them or there was loads of new ones on ebay when i got mine. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 22, 2015 I meant the relay btw Quote Share this post Link to post Share on other sites
deano46 10 Posted July 23, 2015 Just changed them the fuel pump relay and still no joy. Onto the next item tomorrow. Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 23, 2015 Change those sensors bud . If that does not work , get the fuel pressure checked . Quote Share this post Link to post Share on other sites
deano46 10 Posted July 23, 2015 Thanks going tps again tomorrow for senders, housing, stat and stat gasket ring and of course a replacement for the loud aux water pump. Fingers crossed she will be good as new and MOT'd and ready for the sunshine. Quote Share this post Link to post Share on other sites
deano46 10 Posted July 30, 2015 Okay so I have replaced the aux water pump last night. I drained the coolant and went to remove the thermostat housing but can't seem to budge the 5mm Allen head bolts that hold the plastic housing to the block. Any ideas? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted August 2, 2015 Tap the end of the bolt with a hammer and punch, get a bigger ratchet, cross everything for luck and give it more umph. Good luck Quote Share this post Link to post Share on other sites
