maikki 10 Posted August 8, 2015 When sunroof went in it ripped cloth. Before I glue it back is it possible to adjust sunroof bit higher so it would't happen again? When closed sunroof seems to even with roof. Quote Share this post Link to post Share on other sites
Cressa 45 Posted October 28, 2015 From the outside roof of the car, it should sit 1mm below at the front, and 2mm higher at the back. Adjustment is made from the inside by the 2 bolts on either side of the panel. This is probably too late, but may help others Quote Share this post Link to post Share on other sites
maikki 10 Posted November 2, 2015 In wheeler dealers it seemed to be easy job to take off sunroofs inside panel. Quote Share this post Link to post Share on other sites
Cressa 45 Posted November 2, 2015 oo, I've read that you can turn the inner panel 90° and removed it that way. BUT have tried and cannot do it. My headlining is out, so I've slid it backwards and out the boot. Although if you are just wanting to move the inner back to gain access, give it a shove and it comes off its clips to allow access to the metal panel Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 2, 2015 If you put the sunroof in the tilt position, the panel should just slide up and out of the rear when you push down on the retaining tabs each side. Quote Share this post Link to post Share on other sites
