robrado974
Rear hubs question .
Evening all.
As some of you know im sorting the underside of the car atm . I was going to renew the rear hubs , but is there any point if the new ones will rust anyway and end up like the set i have on the car now ?. I was thinking of rubbing mine down and painting them .
Or do they make any now with some sort of coating on them ?.
Many thanks ,
Rob
You mean the rear stub axles Rob? If so, check the mating surface to the rear beam first, as it really needs to be perfectly flat so any corrosion could cause the alignment to be out. If you are happy to re-use them, just make sure the corrosion isn't too bad by chipping a bit of it away. If you're in any doubt about its integrity then obviously change them as a matter of course.
Thats the part Sean yeah . I meant the stubbies . I think mine will need a good going over then , the mating surfice is a bit sketchy .
Thanks mate .
