lilfuzzer
A list of early parts from a 91 car
If there is something you dont see please just ask. I will add to the list once sorted out. All prices are plus postage
Interior
[TABLE=width: 467]
[TR]
[TD][TABLE=width: 467]
[TR]
[TD]Speedo sunround [/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Binnicle covers [/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Early Headlight Switch[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Early fog light swicth[/TD]
[TD] £ 6.00[/TD]
[/TR]
[TR]
[TD]early rear screen switch[/TD]
[TD] £ 6.00[/TD]
[/TR]
[TR]
[TD]ABS light part number535 919 235B[/TD]
[TD] £ 12.00[/TD]
[/TR]
[TR]
[TD]C pillars grey pair [/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]A pillars grey pair no alarm holes[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]B pillars grey pair [/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Headlining good condition [/TD]
[TD] £ 60.00[/TD]
[/TR]
[TR]
[TD]Early sunroof switch and surround[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Black early interior light [/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Pair of sunvisors good condition[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]rear view mirror[/TD]
[TD] £ 8.00[/TD]
[/TR]
[TR]
[TD]pair of parcel shelf supports grey a few small nicks but generally good[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Full set of seatbelts[/TD]
[TD] £ 25.00[/TD]
[/TR]
[TR]
[TD]rear ash tray grey [/TD]
[TD] £ 3.00[/TD]
[/TR]
[TR]
[TD]Parcel shelf grey one strap snapped[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Pair plastic sill trims [/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Pair of door card trims top and bottom[/TD]
[TD] £ 35.00[/TD]
[/TR]
[TR]
[TD]Early door pulls and surrounds[/TD]
[TD] £ 17.00[/TD]
[/TR]
[TR]
[TD]Pair early door grab handles[/TD]
[TD] £ 8.00[/TD]
[/TR]
[TR]
[TD]Pair early speaker covers in grey[/TD]
[TD] £ 25.00[/TD]
[/TR]
[TR]
[TD]Pair early window switches[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Early bare dash grey[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Set of early dash vents, housings and ashtray[/TD]
[TD] £ 35.00[/TD]
[/TR]
[TR]
[TD]Early heater control panel[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Speedo with lockwood dials mileage 133239[/TD]
[TD] £ 35.00[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
[TABLE=width: 467]
[TR]
[TD]C/L pump and housing [/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Non hump centre tunnel upper and lower parts no damage to lugs grey[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Upper and lower gear stick surround missing badge with leather gaitor[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Isotta aftermarket gear knob[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Jack and tool set[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]grey space saver boot carpet bit mucky but will clean ok[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]pair boot side carpets grey a little mucky but will clean ok[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Boot foam x 3[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Passenger side early door loom[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]early heater box and mechanism (sliders and cables)[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Passenger side body door seal no damage or splits[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]ABS ECU 1H0 907 379[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Bare fusebox 357 937 039[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Pair of early stalks[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Headlight loom[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Passenger side kick tray[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]drivers clutch rest[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]speedo loom 2.0 16v[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Fog light switch loom 357 971 056[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Early drivers door loom has been spliced for alarm and one of the plastic connector has damage but still locks fine[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Early iginition loom spliced for an alarm [/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Early heater and stereo loom 536 971 052AB & 536 971 282[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]ABS switch loom for switch number 535 919 235B[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]C/L and window module loom[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Window control module[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD]Front and rear seats and matching early door cards grey cloth[/TD]
[TD] £ 50.00[/TD]
[/TR]
[TR]
[TD]Pair of door pin surrounds [/TD]
[TD] £ 7.00[/TD]
[/TR]
[TR]
[TD]Pair of interior door triangles [/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Handbrake cover grey no splits [/TD]
[TD] £ 13.00[/TD]
[/TR]
[TR]
[TD]Dash drivers undertray grey[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]Dash pass undertray grey[/TD]
[TD] £ 8.00[/TD]
[/TR]
[TR]
[TD]Fusebox cover tray grey[/TD]
[TD] £ 7.00[/TD]
[/TR]
[TR]
[TD]sunroof interior trim[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]inner windscreen trim[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]set of 4 seat belt trim covers[/TD]
[TD] £ 10.00[/TD]
[/TR]
[TR]
[TD]seat slider rails covers pair[/TD]
[TD] £ 10.00[/TD]
[/TR]
[/TABLE]
Exterior
[TABLE=width: 467]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Set of three windscreen trims slight damage on centre one not seen once fitted[/TD]
[TD] £ 20.00[/TD]
[/TR]
[TR]
[TD]Windscreen wiper motor and mechanism[/TD]
[TD] £ 15.00[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]4 x 100 space saver[/TD]
[TD] £ 5.00[/TD]
[/TR]
[TR]
[TD]Expansion tank cover [/TD]
[TD] £ 3.00[/TD]
[/TR]
[TR]
[TD]Plastic scuttle tray[/TD]
[TD] £ 15.00[/TD]
[/TR]
[/TABLE]
Need the plastic scuttle cover and the 3 piece scuttle trim at foot of the windscreen. Is the sunroof trim the head lining part of the sunroof?
Thanks,
Billy
  Alty said:
Hi, I'm looking for a fuel pump connector looks like this..... http://www.epmtuned.com/sitebuildercontent/sitebuilderpictures/.pond/DSC01252.JPG.w300h225.jpg
However, i need to make sure it only has one grove on the top of the plug, Seems most I've found have 2 groves.
Thanks Scott
Hi scott I may have one from a different car will take a look in bag of plugs
Hi billy they are yours
The sunroof trim is the vit tgat meets between the sunroof and headlining. I can sort the sunroof panel out if you like
  SR_Neale said:
Cheers mate. Can you pm me with payment details. Will have the money on Friday (pay day) if that's ok with you.
will do bud will pm with that and pics
