Bfstrachan
under dash trim - whats missing?
pretty sure i'm missing some trim under the passenger side dash. there has obviously been issues and i'm still trying to get to grips with a wet foot-well, but could you all advise what i am needing and if you happen to have it, let me know.
Thanks!
[ATTACH=CONFIG]82606[/ATTACH]
If that's where I think it is (passenger side shelf) then there should be a plastic back to it. If I recall they are different depths depending on whetehr the car has aircon or not. So maybe it was removed when converting to aircon or removing it?
To my knowledge there is no a/c. It's a 1.8 16v 1990. Looking to get that area sorted out as it is a bit of an eyesore.
Thanks for the reply
It's the same across all cars (apart from those with aircon) so I'd suggest asking in the cars breaking section.
I've had a look in the Bentley manual and it simply refers to it as the tray. It also seems to be one piece (ie the undertray and the missing back part seem to be one piece). I can't get to the car right now to check but I wonder if it's been cut out rather than simply a piece missing? If so then you'll need the complete passenger tray which should have the back on it.
Very interesting but due to the squareness would agree with install.
Shall I add the tray to the list billy?
