MikeVR6 0 Posted November 24, 2015 Packaging opened but unused. Bought in error. Please check the profile of your existing seal matches this one before ordering. [ATTACH=CONFIG]82727[/ATTACH] For Passat "35i" B3/B4 1988 - 1996 £35 inc P&P. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 2, 2016 Packaging opened but unused. Bought in error. Please check the profile of your existing seal matches this one before ordering. [ATTACH=CONFIG]82727[/ATTACH] For Passat "35i" B3/B4 1988 - 1996 £35 inc P&P. still got this ? Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 I think so. Either in the boot of the car or the garage. Let me look over the weekend. Like I said in the Ad, make sure it's the same profile as the one on the car. I made that mistake. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 2, 2016 Reason for asking is I've just picked up a b4 moon roof so assume this would be OK? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 2, 2016 Also sorry I assume this is for the glass? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 No Pete. That was the same mistake I made. This is for a B4 SOLID roof. I'll look out the part # for the glass roof and post back. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 357877209A From a Golf. Make a Google Image search and you'll see images with the profile of the seal. Check that against yours. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 2, 2016 ah yes I see the difference - cant believe how much they are for a bit of rubber!! jeeeez - think I'll just have to make do unless you are aware of anywhere that can source these cheaper? Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 Unfortunately not. Surprising as they're common to many VW group cars. €87.00 I paid for mine last year from these guys.. https://www.online-teile.com/volkswagen-ersatzteile/ That was back when the exchange rate was good. Quote Share this post Link to post Share on other sites
fla 9 Posted September 2, 2016 whats the profile of the seal - i'm sure it must be available as a standard or a very-close-to-standard profile? The issue is if its too thick it wont close and if its too loose it wont seal, although i find it hard to believe that that is indeed a water tight seal. Is there a rain collection tray in the sunroof cassette? I just had a look through my sunroof in the closed position, with the headliner and inner panel removed and i could clearly see light shining through. About 1mm wide around the sunroof seal Edit: sorry, this is a For Sale thread, i'll try and shift this to an Interior thread instead. You can tell what area of the car i'm working on from my recent posts!! Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 (edited) Indeed, the seal's designed to be water resistant rather than water tight, there's a rain tray and 4 drains around the corners of the roof. My seal was totally perished and I was getting a lot of water, even from a light shower and lots of wind noise too. Edited September 2, 2016 by MikeVR6 Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 2, 2016 Reason is I've just got a mk3 cassette and a Passat b4 glass and was just freshening it up but the price of the seal is double that I've paid Assume I can replace at a later date without removing the roof lining again ? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted September 2, 2016 Yes the glass is only held on by 4 torx you can access from inside the car. You'll need to adjust it a few times via these anyway to get it level with the roof and cut down the wind noise. Quote Share this post Link to post Share on other sites
