robrado974
Cig lighter plug stuck .
Evening all .
I received my Seat cig lighter today , with the red surround . I plugged it in to check it and it works fine , not that I would use it anyway . But it does not light up but it does get hot and pop out . Obviously there is a new bulb in the unit . Also I went to unplug it as it feeds in the other way into the plastic surround and I can't release it . I'm pressing the lugs together and pulling but it is as tight as , my fingers are dented lol . Maybe I could press the lugs in and pull it with plyers? . I don't won't to break it though .
Any thoughts chaps .
Rob .
Rob, you could try levering it out carefully with a wide flat screwdriver, first one side then the other. That should 'break' the friction and hopefully get the connector off. Hope that makes sense?
Actually now that you mention it I remember struggling like mad when I was trying different options on mine. I found the screwdriver the only way.
