MZpog 10 Posted January 20, 2016 Seems I must have a small leak somewhere on the coolant system of the valver and I've had to top up the coolant a couple of times of late. The carpets are dry and windows don't steam up excessively so I'm guessing (and praying) it's not the heater matrix. Under the hood there doesn't seem to be any obvious leaks. So what I'm looking for is some ideas as to where to focus my search efforts. Stuart. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 20, 2016 Have a look around hose connection points. The water may be evaporating off if the engine bay is hot, but you'll have a pink/white Crystal type substance left over which is the antifreeze. Other than that, thermostat housing or radiator are worth investigating further. Try to get you head around them all and underneath whilst the engine is running and up to temp so the system is pressurised, as that's the best time to notice anything amiss. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted January 20, 2016 If I remember Stuart there are a couple of plastic water flanges on the front and end of the cylinder head that are prone to cracking/leaking, as Sean says the telltale is the pink "stains" from the coolant leaking. Might be worth looking here if you need some: http://www.vwspares.co.uk/corrado_cooling.php Ian. Quote Share this post Link to post Share on other sites
MZpog 10 Posted January 20, 2016 Thanks guys. No signs of the pink stains when I did my quick look, but will get it on the ramps soon to have a proper look. Quote Share this post Link to post Share on other sites
Dox 26 Posted January 20, 2016 Bottom corners of the radiator on any car My other halfs A3 yesterday Quote Share this post Link to post Share on other sites
lesarcsneil 0 Posted January 20, 2016 My original radiator started to leak, but only when warming up. Cold - no leaks, hot - no leaks. Only discovered this when working on another problem in a cold garage and steam started to come off the radiator. Cold weather has it's uses sometimes :-) Neil Quote Share this post Link to post Share on other sites
