JimmyC92 10 Posted January 24, 2016 The dreaded topic! My sunroof will tilt, won't go back and opens when you lock the car. Any suggestions other then use the search function? I'm not particularly confident with electrics. Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted January 24, 2016 Does the roof go back slightly then stop or won't move at all backwards? Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 24, 2016 Seems strange it does it when you lock the car. Do you have an aftermarket alarm that would close everything b4? Quote Share this post Link to post Share on other sites
JimmyC92 10 Posted January 25, 2016 Does the roof go back slightly then stop or won't move at all backwards? Exactly right! Quote Share this post Link to post Share on other sites
JimmyC92 10 Posted January 25, 2016 Seems strange it does it when you lock the car. Do you have an aftermarket alarm that would close everything b4? It's got a Clifford alarm, I'm not sure if that's factory fitted or not! Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 25, 2016 Just wondering if you could disconnect your alarm, somehow remove a fuse and see if that allows it to open correctly. .. worth a try. Or contact the person who fitted the alarm and see if it sounds like that could be a problem.... only costs a phone call Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 25, 2016 Clifford aren't factory fitted Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted January 25, 2016 odd that it is opening when locking car I do recall that an alarm fitter once told me that to enable the full closure function on the alarms it is only normally one wire that needs to be connected - not sure how you could get that the wrong way round or somehow connect it up in the opposite way it should be but it sounds along those lines what happens if you close the door using the key in a 'turn & hold' fashion? normally this would operate the full closure function from the door lock & close the sunroof & windows if open if the above functions normally I would say the alarm is not quite wired correctly for the full closure - if not then it points elsewhere Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 25, 2016 Did it work ok b4.... Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted January 25, 2016 Is it possible that a sensor thinks the sun roof is open so when the closure of the alarm kicks in it tries to shut the roof. This is based on a guess that the motor spins one way to bring it backwards and the opposite way to close it which would be the same direction to tilt it. Might explain why it won't go back cos it thinks it's already open. Just a thought. Quote Share this post Link to post Share on other sites
cmalyan 11 Posted January 25, 2016 Have a look at this thread, you should find the answer here - same issue...... http://the-corrado.net/showthread.php?34786-Sunroof-Journal-Voyage-of-Discovery/page2 Quote Share this post Link to post Share on other sites
Jim 2 Posted January 25, 2016 odd that it is opening when locking car I do recall that an alarm fitter once told me that to enable the full closure function on the alarms it is only normally one wire that needs to be connected - not sure how you could get that the wrong way round or somehow connect it up in the opposite way it should be but it sounds along those lines what happens if you close the door using the key in a 'turn & hold' fashion? normally this would operate the full closure function from the door lock & close the sunroof & windows if open if the above functions normally I would say the alarm is not quite wired correctly for the full closure - if not then it points elsewhere I think this is what you need to try - lock the car, using the key, and hold it turned in the lock position. This activates the Corrado's built in full closure mechanism. If it does open the sunroof, then at this point the problem is with your sunroof motor being out of sync with the actual position of the sunroof mechanism and will need resetting. I should imagine if you were to close the sunroof to the position you want it, then drop the motor out of the roof but leave it connected (so it can't actually drive anything) then lock the car using the full closure, the motor will reset itself to the position it considers 'correct'. Then you could reinstall the motor back into the roof and should be all good to go? Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted January 25, 2016 Slightly off topic but do early sunroof motors have the Allen key to move the motor manually. I have taken mine out and still can't find it. Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 25, 2016 Is there a small black plastic cover with a white arrow on yours? If so move it 90°and you'll see its covering the Allen key manual release fitting Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted January 25, 2016 Will go have a look now. Cheers Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted January 25, 2016 Is there a small black plastic cover with a white arrow on yours? If so move it 90°and you'll see its covering the Allen key manual release fitting My motor hasn't got one so I guess that's the case with all early motors. Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 25, 2016 Sorry I can't help anymore. This is a later model one I've pictured Quote Share this post Link to post Share on other sites
JimmyC92 10 Posted January 28, 2016 Just wanted to thank everyone for your input! I have a day off tomorrow so I will be giving a few things a bash! Quote Share this post Link to post Share on other sites
JimmyC92 10 Posted February 12, 2016 Well I have managed to stop the sunroof opening when I lock the car, however it still won't retract fully, it gets to a point and then stops, the motor doesn't even seem to attempt to push it back, no noise at all! Is it possible the part of the motor that fully retracts the sunroof is faulty? To my find if the motor was faulty it just wouldn't work at all? But I'm new to Corrado's! Quote Share this post Link to post Share on other sites
JimmyC92 10 Posted February 12, 2016 I think this is what you need to try - lock the car, using the key, and hold it turned in the lock position. This activates the Corrado's built in full closure mechanism. If it does open the sunroof, then at this point the problem is with your sunroof motor being out of sync with the actual position of the sunroof mechanism and will need resetting. I should imagine if you were to close the sunroof to the position you want it, then drop the motor out of the roof but leave it connected (so it can't actually drive anything) then lock the car using the full closure, the motor will reset itself to the position it considers 'correct'. Then you could reinstall the motor back into the roof and should be all good to go? Just wanted to say thank you! Gave this a bash and it now doesn't open when I lock the car! Still an issue that it won't fully retract but it will tilt! Quote Share this post Link to post Share on other sites
Jim 2 Posted February 12, 2016 Wow - I actually gave some useful technical information that helped resolve the problem. Pinch me, I'm dreaming :) Glad I could help! :) How far will it open before stopping? I wonder if something is jammed in the mechanism somewhere, stopping it from fully opening. The Corrado sunroof is, sadly, a notorious problem spot so you certainly aren't the first and won't be the last to run into problems with one! :( Quote Share this post Link to post Share on other sites
