C. Will Corrado G60 2
Small front number plate???
Hi,
I've been wanting to update my front end a little and have seen a few C's with the front number plate moved down under the bumper and filled the hole. Nice look!
The number plates look smaller, does anyone know where can I get one from and is it legal?
cheers
To keep in line with the rozzerz, the numbers have to be the correct height, width, & have the correct spacing between them.
And 11mm of space to the edge of the plate itself.
Check the DVLA site if you are concerned!
HTH
Ive smoothed my front bumper and relocated plate,but i stuck to the right size plate to keep the feds happy :lol:
Im guna completly smooth it soon and do away with indicators and fogs!
Bally, your car is still one of my favourites on the forum :wink:
cheers Matey.. :wink: need to stick some updated pics up... :D
Hey flusted get some pics up of yrs then?? :D
when I get time/money I wanna smooth the bumper and move the plate, like the Green C on the back of the Jan 2004 Sprinter, looks loverly imo 8)
only the pic in my avatar.
Ordered some plates for Fancyplates.com on thursday. Arrived yesterday, very impressed. I ordered front and rear plates with honeycomb background, std UK font and the custom sizes. The rear plate is 420mm x 100mm and the front is a 3/4 size bike plate i think. Recommended
im in the process of smoothing fogs, indicators & plate at the mo!! 1/2 way there!!!
Doin mine tommorrow! tryin to think of a way to do it without the filler cracking :roll:
well as the bumper is made of abs you could get a plastic soldering kit and use some bits off of an old bumper to fill in the holes and then make the plastic "welds" a little big and then sand them down then use minimal filler. Prolly be a good idea to brace it on the backside of the bumper as well to add stability. IIRC plastic soldering kits ususally consist of a high wattage soldering gun and some plastic filler rods. A mate of mine used this when he frenched his rear plate into bumper. Came out quite nice and has run for 2 years with no cracks or anything..
Ended up filling the holes with expanding foam(good fun) then filled over the top.I wouldve gone down the plastic welder route if i couldve found one as i used to use 1 when i worked at f#rd
don't you have to supply 100s of forms nowadays for plates?
how do they do that online?
['H3R4POR]don't you have to supply 100s of forms nowadays for plates?
They're not based in the UK so the rules don't apply to them.. ;) :D
lol, genius :)
I'm considering putting black old style ones on my car, to almost match the painwork, does anyone know if these are legal to put on?
you still see classic cars with them on, so they must be legal in some respects, might have to be genuine to the year though
You can only put them on car registered before 1975 or some thing like that!
Its in that £1000 fine catergory!
Black and silver number plates are only legal on cars registered before August 1972... (L plate or before)
as gibber_2k, says, £1000 fine if they're in an arsey mood when you get caught... :? :(
