John Blount
Need a replacement Aerial base and gasket for 95 VR6
Can anyone recommend a replacement aerial base and where to get one from?
Mines all split plus the gaskets missing and it's going for a re-spray in June so I need to get one.
Anyone brought one that's a known fit??
I just ordered a 'genuine' one from eBay but the seller only had one. It's not arrived yet for me to confirm it's a direct fit but the part number was 3B0051751.
Found this one too but not sure what you're looking to spend . . . There may well be cheaper elsewhere.
http://m.ebay.co.uk/itm/Genuine-VW-Golf-Roof-Aerial-Antenna-Gasket-Seal-Kit-OE-/171991571880?nav=SEARCH
I recently brought a couple of these
soak in some hot water prior to fitting & they just about squeeze over the top of the aerial base
http://www.ebay.co.uk/itm/REPLACEMENT-VW-CORRADO-BORA-ROOF-AERIAL-ANTENNA-RUBBER-GASKET-GROMMET-SEAL-/281611976603?hash=item419161bf9b
I got mine of the bay,all brand new,amplified base and gasket
What year is your car though? Mines a 95 and all the aerials I've seen have the wrong connector! I believe I need a RAKU 1 aerial but all of them I've seen on e-bay etc are RAKU 2 meaning it won't connect to the cable running to the radio?
Woops, replied to the wrong post!
Edited by Dox
