Dox 31 Posted April 7, 2016 (edited) I've just had my VR6 fail on emissions and was offered this advice by an online friend - it maybe of use to others? Does it need a cat test EMISSIONS HELP CO high, co2 low hc high, o2 high - rich mixture with ignition misfire CO high, co2 low hc high, o2 low -faulty thermostat or coolant sensor CO low, co2 low hc low, o2 high - exhaust leak after cat CO low, co2 high, hc low, o2 high - injector misfire, cat ok CO high, co2 low, hc medium to low, o2 high - rich mixture CO high, co2 high, hc high, o2 high - injector misfire, cat not working, combination of rich mixture and vacuum leak CO low, co2 high, hc low, 02 low, good afr and cat operation- system normal . lambda typical range 0.97 to 1.03 [ ideal lambda 1 ] The emissions limits to be met are specified for both the fast and normal idle tests. At fast idle, CO must be at or less than 0.2%, HC at or less than 200 parts per million (ppm), and the lambda value(1) must be between 0.97 and 1.03. At normal idle, CO must be at or less than 0.3%. Edited April 7, 2016 by Dox Quote Share this post Link to post Share on other sites
swiftkid 1 Posted April 7, 2016 There is a loophole for those with engine conversions struggling with emissions, if your car is aged between 92 and 95 and your car is not listed on the analyser database (as specified on page 9 above) then you get 3.5% rule. But here's the twist, a corrado vr6 or corrado 1.8 will be on the database but a corrado r32 or 1.8t will not! Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
