Gjlaw1 11 Posted April 24, 2016 Hi - quick note to say hi - I've just joined - I've got a 16v in need of some serious love - it's not been used in 10 years!! - if I can figure out how to post pictures I'll start a thread to show progress of my mission hopefully ending with it running/driving!! Thanks Gareth Quote Share this post Link to post Share on other sites
southerner88 10 Posted April 24, 2016 hello and welcome along - plenty of people on here with the knowledge to help you get going... Many people upload photos to another website and copy in the link I think, personally, I prefer using the tapatalk app, find the Corrado Forum on it and sign in, then you can get pictures up really easily! Hope that helps and look forward to seeing the progress... Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 24, 2016 Hi Gareth, I'm probably not far from you in Wootton with a 16v, give us a shout if you want a second pair of eyes on anything, I know the 16v pretty well, having owned one for 20 years :) Quote Share this post Link to post Share on other sites
ed.speller.7 10 Posted April 24, 2016 Hi Gareth I'm from Irthlingborough and bout to remove my 16v engine from my rado if u need any engine related parts Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 24, 2016 Thanks David - you're not far at all (I'm in Grendon).... Let me know if you are passing close-by any time. All advice welcomed!! I've yet to get it to turn over (got distracted with a door lock mechanism then later a bucket and sponge!)....the engine really is in a bad way! [ATTACH]83727[/ATTACH] Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 24, 2016 Hi Gareth I'm from Irthlingborough and bout to remove my 16v engine from my rado if u need any engine related parts Yes please - I think I need everything (see earlier picture of what I'm faced with!) I'll pm you my contact details... Cheers Gareth Quote Share this post Link to post Share on other sites
Jim 2 Posted April 25, 2016 Yikes! That engine bay isn't pretty! The fuel lines, etc are the most corroded I think I've ever seen, but hopefully it is all just surface corrosion and you can get it running easily enough. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted April 26, 2016 If the picture is a guide wonder what the rest of the car is like. What are your intentions with it, and should be a good one to follow. Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 26, 2016 Well it's going to be challenging! I'm no mechanic but like tinkering - I'm discovering and learning as I go. My Intention/dream is to get it to run/drive - it's been ignored for 10 years and it feels like it deserves to live - I'm a sucker for a charity case! Keen to keep it original so will be seeking many standard parts! Callipers seems like a good place to start, anyone got any left overs of any standard parts I could use? Still haven't got it turn over - do they all have the led in the dash (below) or does this confirm it has an alarm/immobiliser that may be stopping it from turning. Cheers all.... Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 27, 2016 LED is likely to be alarm or immobiliser. If I don't start my car within about 30 seconds, my LED flashes again as it resets the immobiliser. Quote Share this post Link to post Share on other sites
'Rado_TDI 10 Posted April 27, 2016 wowser! good work for rescuing the old sausage! Quote Share this post Link to post Share on other sites
MarkR 11 Posted April 27, 2016 All credit to you for even attempting to restore. For experience it is likely that the old alarm is knackered and would be best removed. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted April 27, 2016 Blimey that is bad you are brave hope you have a large wallet. Quote Share this post Link to post Share on other sites
ferarrifeet 0 Posted April 27, 2016 if you've got problem with alarm there's a valet mode you can switch off that will let you start car better.my switch was located at side of drivers seat on tunnel, have heard some put them under gear stick cover. hope this helps Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 28, 2016 Good news, bad news and a bit more bad news.....found the 'hidden' key/switch for the alarm (thanks for the tip to hint it out) - bad news it was already switched off so not the cause of the starter not turning...... Anyone know where I can get a battery tray from ? VWheritage are out of stock..... Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
edd 0 Posted April 28, 2016 I have a mk2 golf one and a corrado one (not sure which one I'm going to use yet) so will have one of them up for grabs but I just need to get round to it. The mk2 golf one is pretty much identical though except it doesn't have the section that goes back to the bulkhead Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 28, 2016 Hi Edd - the mk2 one would be great (if available) it's just the front section that I'm looking to cut out/replace.... Let me know if it's up for grabs, how much etc.... Cheers Gareth Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
edd 0 Posted April 28, 2016 Will do. It won't be for a few months though so be warned.... Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted April 28, 2016 Ok thanks - I may get to that job on the list a bit sooner, although it is a very long list!! Cheers Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 17, 2016 Any updates? Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted May 17, 2016 Hi Sam - well I've been busy..... Starter motor on, new fuel pump fitted, resistor from a Passat sender utilised!, inlet manifold, fuel lines, air intake bit, distributor, leads etc all swapped over from your old engine...fuel pump relay swapped (now clicks and fuel pump primes). Engine turns on the starter motor, has a spark but no fuel is getting up to the engine - disconnected the fuel line from the pump and turned ignition on - petrol is drawn up/comes out but not getting from the rear of the car to the front!! Am I right in thinking there is a fuel filter underneath that may be bunged up? Again, any advice welcomed!!cannot wait to get the engine running! Cheers Gareth Quote Share this post Link to post Share on other sites
Jim 2 Posted May 17, 2016 Yep - there is an in-line fuel filter under the car. Could very well be a blocked, mummified piece of crap under there if it's never been touched so I'd be looking there next :) Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 17, 2016 http://wiki.the-corrado.net/16v_fuel_filter_replacement.html This will help you find it, as above, its going to be in a sorry state if the rest of your car is anything to go by! Quote Share this post Link to post Share on other sites
Gjlaw1 11 Posted May 18, 2016 Thanks - anyone know what the bit below on the left is (round, brown and crusty which to be fair is pretty much everything!) plus the black square box thingy? Looks like fuel lines go into it so keen to replace.... Anyone got one? Cheers gareth Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 18, 2016 thats the inline fuel pump Quote Share this post Link to post Share on other sites
