lilfuzzer 1 Posted May 21, 2016 (edited) I have many parts from this car as listed below. I will continue to add to the list when I can. If you dont see anything you would like drop me a message as have been hoarding for nearly 20 years now and need to let go of a few things All prices are plus postage. Multiple purchases welcome (discount will be offered) Thnaks [TABLE=width: 467] [TR] [TD]sunroof switch[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]paasenger side upper grab handle[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]Late cig lighter[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]late headlight switch[/TD] [TD] £ sold[/TD] [/TR] [TR] [TD]pair of grey door pods (Late)[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]pair of grey speaker grills (Late)[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]pair of inner door triangles[/TD] [TD] £ 8.00[/TD] [/TR] [TR] [TD]pair of sunvisors ther is a crack in the pass plastic covering[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]Speedo sunround crack around screw hole but not seen once covers on[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]Late front ashtray and backing[/TD] [TD] £ 16.00[/TD] [/TR] [TR] [TD]Plastic grey handbrake handle cover[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]rear view mirror[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]late sunroof switch surround[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]ABS light 535919235AAsold[/TD] [TD][/TD] [/TR] [TR] [TD]foglight switch[/TD] [TD] £ 8.00[/TD] [/TR] [TR] [TD]rear demister switch[/TD] [TD] £ 8.00[/TD] [/TR] [TR] [TD]Dash drivers undertray grey[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]Dash pass undertray grey[/TD] [TD] £ 8.00[/TD] [/TR] [TR] [TD]Fusebox cover tray grey[/TD] [TD] £ 7.00[/TD] [/TR] [TR] [TD]central dash blank[/TD] [TD] £ 7.00[/TD] [/TR] [TR] [TD]spolier swicth[/TD] [TD] £ 8.00[/TD] [/TR] [TR] [TD]paasenger side late window swicth[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]drivers grab handle with mirror swicth[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]boot popper[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]pair rear selt belt covers[/TD] [TD] £ 12.00[/TD] [/TR] [TR] [TD]pair of door card trims upper and lower sections[/TD] [TD] £ 40.00[/TD] [/TR] [TR] [TD]passenger side grab handle[/TD] [TD] £ 8.00[/TD] [/TR] [/TABLE] [TABLE=width: 564] [TR] [TD]Front 2.0l 16v engine carrier[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]Front rad cradle 16v some surface rust[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]grey parcel shelf grubby and one strap mising[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]pair grey c pillars[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]grey rear centre pillar trim[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]set boot foam x3[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]set of seat belts[/TD] [TD] £ 30.00[/TD] [/TR] [TR] [TD]window control module[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]pair grey b pillars[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]c/l pump and housing[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]VR6 steering wheel worn but not through[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]rear grey ashtray[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]late adjustable steering cowling upper and lower[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]16v clocks showing 152k[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]Late steering stalks pair[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]Pass side grey kick tray[/TD] [TD] £ 5.00[/TD] [/TR] [TR] [TD]pass side under dash tray grey[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]windscreen wiper motor[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]2.0l 16v ecu[/TD] [TD] £ 30.00[/TD] [/TR] [TR] [TD]late grey dash with centre insert some damage though[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]pair grey a pillars with alarm holes at the top[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]set of air ducts[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]ABS ECU[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]pair grey door sills[/TD] [TD] £ 15.00[/TD] [/TR] [TR] [TD]drivers grey kick tray[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]headlining[/TD] [TD] £ 40.00[/TD] [/TR] [TR] [TD]sunroof beading[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]steering column (adjustable)[/TD] [TD] £ 40.00[/TD] [/TR] [TR] [TD]Fusbox[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]pair of pearl green wing mirrors[/TD] [TD]sold[/TD] [/TR] [TR] [TD]pair inner door triangles[/TD] [TD] £ 10.00[/TD] [/TR] [TR] [TD]pair outer door triangles[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]pair front bumper brackets (guides)[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]drivers window no scratches needs guide[/TD] [TD] £ 25.00[/TD] [/TR] [TR] [TD]drivers window regulator[/TD] [TD] £ 40.00[/TD] [/TR] [TR] [TD]heaterbox[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]pass window no scrathes needs guide[/TD] [TD] £ 25.00[/TD] [/TR] [TR] [TD]pass window reg[/TD] [TD] £ 35.00[/TD] [/TR] [TR] [TD]windscreen trim x3[/TD] [TD] £ 25.00[/TD] [/TR] [TR] [TD]set of bump strips[/TD] [TD] £ 30.00[/TD] [/TR] [TR] [TD]2x ABS wiring to hubs[/TD] [TD] £ 20.00[/TD] [/TR] [TR] [TD]inner windscreen top trim[/TD] [TD] £ 20.00[/TD] [/TR] [/TABLE] Edited June 12, 2016 by lilfuzzer Quote Share this post Link to post Share on other sites
gotvach 10 Posted May 23, 2016 Could I have the ABS light and headlight switch (posted to UK) please? ( I assume these are used parts but working :) ) Quote Share this post Link to post Share on other sites
16VG60 1 Posted May 23, 2016 Do you have a 9A engine available from this breaker? If yes I would like to discuss its condition and price please. Also, do you have a late complete, dash centre insert? Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 23, 2016 gotvach said: Could I have the ABS light and headlight switch (posted to UK) please? ( I assume these are used parts but working :) ) yes mate have your name on them Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 23, 2016 16VG60 said: Do you have a 9A engine available from this breaker? If yes I would like to discuss its condition and price please. Also, do you have a late complete, dash centre insert? Hi John Yeah engine available not sure on condition as its spitting fuel out of one of the lines hence not enough pressure to get enopugh fuel through to run It appears to turn over well. The dash insert is ccracked in places mate sorry. If you want to have a chat about the engine drop me a message and I can send my number over Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted May 23, 2016 How much for the entire wiring loom? Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 23, 2016 destructiv dave said: How much for the entire wiring loom? When you say entire loom do you mean all internal looms and engine looms? Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 24, 2016 gotvach said: Could I have the ABS light and headlight switch (posted to UK) please? ( I assume these are used parts but working :) ) still want these? Quote Share this post Link to post Share on other sites
gotvach 10 Posted May 24, 2016 lilfuzzer said: still want these? Yes please. I figured you were going to let me know the total including postage and then I can send over payment via PayPal. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 24, 2016 gotvach said: Yes please. I figured you were going to let me know the total including postage and then I can send over payment via PayPal. sorry for confusion pmd Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted May 24, 2016 lilfuzzer said: When you say entire loom do you mean all internal looms and engine looms? Yep. All of it. I've had electrical problems ever since someone chopped out my fuse box so seeing if this is a more cost effective fix than paying an auto-electrician. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 25, 2016 Ah right mate. Will work it out Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 25, 2016 Do you have scuttle panel? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 25, 2016 culshaw said: Do you have scuttle panel? Sent from my iPhone using Tapatalk Yes mate I do please bear in mind it's the original one that only covers the fan cover and plug for ecu Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 25, 2016 ok, so mine doesn't even cover the ECU... http://i.imgur.com/IjqWPwK.jpg Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 25, 2016 Has it been cut as that looks like original one Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 25, 2016 Zooming in looks like yours covers the ecu plug Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 25, 2016 ok, i'm more after the one that covers the left, thought it was all the scuttle! this bit.. http://www.ebay.de/itm/VW-CORRADO-RHD-FRONT-WINDSCREEN-BOTTOM-WIPER-SCUTTLE-TRAY-LEFT-SIDE-COVER-TRIM-/281801518530?hash=item419cadedc2:g:efEAAOSwQTVV-WX7 Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 25, 2016 Ah sorry pal yes sorry I have one of them pieces in the eBay ad Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 25, 2016 (edited) you know what, i've got my wires completely crossed, i thought it was something to cover the wiper motor not for the windscreen. Ignore me! Edited May 25, 2016 by culshaw Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 26, 2016 do you have the plastic surround that houses the sunrood motor/switch? Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 26, 2016 Yes I do mate you want an early or late? Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 26, 2016 culshaw said: you know what, i've got my wires completely crossed, i thought it was something to cover the wiper motor not for the windscreen. Ignore me! No bother mate Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 26, 2016 destructiv dave said: Yep. All of it. I've had electrical problems ever since someone chopped out my fuse box so seeing if this is a more cost effective fix than paying an auto-electrician. Pmd Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 26, 2016 Late :) Quote Share this post Link to post Share on other sites
