89G60 10 Posted June 4, 2016 Hi all, new to the group. I'm curious can I fit a vr6 suspension kit i I have on a G60? Got the Shocks and springs, will I need vr6 caps and top mounts..? Also, Will there be no touching of the wheel/strut due to G60 being non-widetrack? I imagine the struts to be physically the same.. Any help would be great Thanks Quote Share this post Link to post Share on other sites
TomBarker1991 10 Posted June 5, 2016 From memory the top mounts and everything are the same (I'll stand to be corrected on that) As for the strut if the G60 has standard suspension on pop a wheel off and take some measurements of the strut on the car and compare Quote Share this post Link to post Share on other sites
89G60 10 Posted June 5, 2016 Seems like after a bit of searching all I need are vr6 spring caps and mounts.. But I'll measure up first as that's a great idea. Cheers Quote Share this post Link to post Share on other sites
TomBarker1991 10 Posted June 5, 2016 If I get chance to get down the workshop today I'll have a look got a couple of VR subframes and two 16v corrados ill see if I can size them up Quote Share this post Link to post Share on other sites
89G60 10 Posted June 5, 2016 If I get chance to get down the workshop today I'll have a look got a couple of VR subframes and two 16v corrados ill see if I can size them up Nice one mate.. Quote Share this post Link to post Share on other sites
Yandards 0 Posted June 5, 2016 No issues with that its all interchangeable and you only have to allow for the faff with spring caps and top mounts, which normally need the internal diameter type. Been running VR6 springs and Koni yellow dampers for years - its a better setup than the 16v/G60 springs and dampers as the 16v springs are designed for use on standard shocks. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 6, 2016 No issues with that its all interchangeable and you only have to allow for the faff with spring caps and top mounts, which normally need the internal diameter type. Been running VR6 springs and Koni yellow dampers for years - its a better setup than the 16v/G60 springs and dampers as the 16v springs are designed for use on standard shocks. good info Yandards thank you timely too as i was donated a set of VR coillies recently & want to put them on an early valver any chance you could expand a little on the 'faff' you mention of spring caps & top mounts pls? thanks Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 10, 2016 good info Yandards thank you timely too as i was donated a set of VR coillies recently & want to put them on an early valver any chance you could expand a little on the 'faff' you mention of spring caps & top mounts pls? thanks hi Yandards - any info on the faff you mentioned pls? MOT in next couple of weeks & i may need to swap the suspension out thanks Quote Share this post Link to post Share on other sites
Yandards 0 Posted June 13, 2016 Hallo, Sorry been away, coilovers should use their own spring caps. To see if the stuff will work you just need to build it all up off the car and confirm the various pieces assemble correctly, ie the spring caps fit the shock absorber and the top mounts fit etc. As you are using coilovers its a lot easier and all types of Corrado have an identical suspension mounting point on the chassis which takes all types of top mounts. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted June 13, 2016 Hallo, Sorry been away, coilovers should use their own spring caps. To see if the stuff will work you just need to build it all up off the car and confirm the various pieces assemble correctly, ie the spring caps fit the shock absorber and the top mounts fit etc. As you are using coilovers its a lot easier and all types of Corrado have an identical suspension mounting point on the chassis which takes all types of top mounts. hello m8 no danger, i appreciate your reply cool, great info thanks :) Quote Share this post Link to post Share on other sites
