garethscott 10 Posted June 14, 2016 after 15 years of not owning one, I'm back in the game, its a bit of a shed but with some TLC will be ok when finished, slight issue with rough running at the moment, need a new induction kit, any out there. thanks Griffer Quote Share this post Link to post Share on other sites
garethscott 10 Posted June 14, 2016 actually changing the above slightly, currently I have this on her: http://www.direnza.co.uk/vw-golf-mk3-8v-gti-rohr-intake-pipe.html all i need are the rubber ends, anyone any ideas? Quote Share this post Link to post Share on other sites
Harrier 1 Posted June 14, 2016 Welcome back to ownership :) Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 14, 2016 Welcome back! Get some pics up when you can. The engine is essentially the same, so a Mk3 Golf GTI 8v induction kit will fit if you're struggling to find one. In all honesty, there probably aren't many second hand ones advertised for Corrados out there. Rough running on this engine are generally down to ISV or MAF sensor. Give the ISV a clean with carb cleaner, and the MAF a squirt with electrical contact cleaner before worrying too much about forking out for replacements. Where are you based? Someone may be close by with VCDS so could read any fault codes for you to save the hassle. :thumbleft: Quote Share this post Link to post Share on other sites
garethscott 10 Posted June 14, 2016 Thanks, based in the Skipton area, all the rubbers have perished so they need replacing Sent from my D6603 using Tapatalk Quote Share this post Link to post Share on other sites
MZpog 10 Posted June 15, 2016 Welcome back to ownership. Get some photographs posted. Maybe I'll see you about some time as you're just up the road from me in Bingley. Quote Share this post Link to post Share on other sites
garethscott 10 Posted June 15, 2016 Welcome back to ownership. Get some photographs posted. Maybe I'll see you about some time as you're just up the road from me in Bingley. I'll put some photo's on as soon as its had a little bit of tlc :) Quote Share this post Link to post Share on other sites
