carrots
J&r driveshafts
Has anyone used these.I fitted a new driveshaft off them and it sounds worse than the one I took off.rumble and a shake,I contacted them and they are sending a new inner c.v. joint.pain having to do the job again tho.I just hope this one's fine
Yeah I have both sides and the only slight problem I had was the boot on the n/s outer is a touch too big, so originally had a bot of Grease leak out. Sorted with a proper banding tool though. Been fitted for about 2k and been perfectly fine. Quite a few others have them fitted too if you do a search, and I think every report until now is a positive one.
