Sommevr6 10 Posted July 23, 2016 Can anyone help- just got the corrado back from being re-painted and checking bits on the vehicle during which I noticed that when I unlocked/locked the car on the remote instead of the front offside bumper indicator flashing with the rest, the fog light flashed instead. I have also had to replace the headlight switch - is this going to be connected to the replacement switch or will something have been reconnected wrongly when the bumper was painted (believe they removed it for paint). Vehicle is a storm model if that has any bearing. Cheers. Quote Share this post Link to post Share on other sites
Dox 23 Posted July 23, 2016 Can anyone help- just got the corrado back from being re-painted and checking bits on the vehicle during which I noticed that when I unlocked/locked the car on the remote instead of the front offside bumper indicator flashing with the rest, the fog light flashed instead. I have also had to replace the headlight switch - is this going to be connected to the replacement switch or will something have been reconnected wrongly when the bumper was painted (believe they removed it for paint). Vehicle is a storm model if that has any bearing. Cheers. A broken or damaged earth wire to lights give all sorts of odd happenings when the voltage then goes on to try and find a path to earth via other connections on nearby lamps Check the wiring to that corner of the car, check the bulb fitment to the lamps too, clean off any corrosion found and make sure the correct type of bulbs are fitted to the lamps too Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 24, 2016 Earth wire shorting or disturbed during the respray. Check all wiring or bring it back and ask them to fix it. Quote Share this post Link to post Share on other sites
Sommevr6 10 Posted July 24, 2016 Thanks for that-looking to go back on Monday to see if it can be resolved but wasn't sure whether it may have been connected to the replacement switch Quote Share this post Link to post Share on other sites
