splinterz1@yahoo.com
Door mirrors.
It's in the manual. A Google for CE2 VW will also throw up a good few results. I can't remember the exact fuse number right now. Use the search, Luke.
A common problem is the actual switch contacts being dirty. I believe there is a Wiki info on here about it. It cured mine and was an easy fix
Sent from my SM-G900F using Tapatalk
cressa - was that the guide on how ti take the switch apart & then reassemble?
if it was i have a copy which i can email out if that would help the OP :)
