delfinis38
Front seat removal
Is it easy to remove the front seats... Mine are heated....if that makes a difference..
If it's a simply job tempted to remove to have a good Hoover...
Do they slide forward or back off the runners...
Hi Delfinis . Yes easy enough to do . There is a nut and bolt at the front just above the floor pan . Then the seat is free to slide back . It takes a bit of jiggling to put them back , but it's not a hard job to do . Just remember to unplug the loom first and fit it back in first .
Piece of wee wee. Remove runner trim, slide seat back and undo bolt on the centre runner. Unplug loom from the Base of the seat and put an old rag or towel down on top of rear mats, slide all the way back and bobs your uncle!
Thanks both of you.
Well done Sean , I forgot about the towel , there is grease on the runners and the front part where the nut and bolt is .
