delfinis38 1 Posted August 10, 2016 Is it easy to remove the front seats... Mine are heated....if that makes a difference.. If it's a simply job tempted to remove to have a good Hoover... Do they slide forward or back off the runners... Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 10, 2016 Hi Delfinis . Yes easy enough to do . There is a nut and bolt at the front just above the floor pan . Then the seat is free to slide back . It takes a bit of jiggling to put them back , but it's not a hard job to do . Just remember to unplug the loom first and fit it back in first . Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 10, 2016 Piece of wee wee. Remove runner trim, slide seat back and undo bolt on the centre runner. Unplug loom from the Base of the seat and put an old rag or towel down on top of rear mats, slide all the way back and bobs your uncle! Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 10, 2016 Piece of wee wee. Remove runner trim, slide seat back and undo bolt on the centre runner. Unplug loom from the Base of the seat and put an old rag or towel down on top of rear mats, slide all the way back and bobs your uncle! Thanks both of you. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 10, 2016 Well done Sean , I forgot about the towel , there is grease on the runners and the front part where the nut and bolt is . Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted August 10, 2016 Might be worth updating the wiki!? http://wiki.the-corrado.net/front_seat_removal.html Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 10, 2016 Might be worth updating the wiki!? http://wiki.the-corrado.net/front_seat_removal.html Cheers.. Quote Share this post Link to post Share on other sites
