gotvach
VR6 1992 Aqua blue
It hasn't torn but the material has shrunk quite a bit making the corner part tricky to put back. I noticed today that the other side is starting to do the same. No harm in trying and perhaps a bit of heat/conditioner might help in massaging it into position.
Got to be worth a try to fix it, little bit of heat should help.
I used evo / bostick to fix my leather rear panels
Yes heat is your friend. Use a hairdryer as opposed to a heat gun. Use a bit of oil on the surface to maintain its pliability.
Got the wheels back from Spit & Polish today after a tyres off refurb. £312 for the four including tyre, removal, refitting, balancing and shorter valves.
They look much better than before and it's nice not to see any corrosion. Although I've got mixed feelings as I thought the finished quality would be much better. But maybe my expectations are too high. At least the colour matching against the centre caps is pretty good and overall the set will look much cleaner.
cf8aed7262f79a63ffcad463d674788d.jpgff9a8afa5778e2bd829da767b764d714.jpg377bba88af7caace16cfe1e6ff070149.jpg30caa137d4515dec47ad642b9c5d0787.jpg56dc48b221e6009a71db055aed903387.jpg1dd7b9339135bb2c4d687181485dfa65.jpg1bb5d206078f57bc671af9c6bc916bb3.jpg
Sent from my HTC 10 using Tapatalk
