It's not a Scirocco
VR nasty growl when cold
Sounds like tired bearings. I assumed it was the water pump as I have replaced the power steering pump thinking this was the problem as it sounded like it was low down.
Before getting stuck in to changing the water pump i took the aux belt of and ran the engine just incase.
Turns out to not be any of the parts run off the aux belt.
So it's something internal. Oil pump? Something worse?
Any ideas?
Thanks Chris
The starter motor , if faulty would only make any noise while cranking the engine on start up ?
How long does the noise last? it could be the starter motor hanging on but that would only last a second or two after the engine has started
Good to hear of a problem solved
Sent from my SM-G900F using Tapatalk
