karmannski
Roof moldings - group buy offer
1.fendervg - PAID
2.Jim Bowen - PAID
3.easypops - PAID
4.gotvach - PAID
5.Louis - PAID
6.Spen - PAID
7.aj117 - PAID
8.JAM11E - PAID
9.Wesleyvr6 - PAID
10.Will.I.Dub - PAID
1.jaybo -
2.Mr_Rossy PAID
3. andyvlw PAID
I'm closing this list now, Shipping all 12 sets Tuesday to myself.
Thanks.
I'm out the country till the 3rd. Can i pay on the 30th?
Cheers
JAson
Sorry mate just saw your post, unfortunately this group buy is finish. You can buy them individually or get 4 more guys and open new group buy.
All 12 sets posted out on Friday to you guys. Hope you will like them.
Check them out guys on your cars hope they will fit well.
Any problems, I don't speak English ;)))) I do not unrerstud .
Wysłane z iPhone za pomocą Tapatalk
Got mine too look great! although some how one cap off the tube Was missing I just want to double check is there only supposed to have a clip on one end or am I missing something? As I can't check because my car isnt available to check on atm
Sent from my D6603 using Tapatalk
Thanks good to know
What clip is missing ? It was all there but Let me know please.
Received mine safely thanks, just fitted them now and I'm not happy with the fit, they are very loose in the channel, it seems as if the tubing the hey are made from is not wide enough to keep them securely in the channel. The moulding doesn't sit flat with the roof in places and flaps about because they are not tight enough?? Anybody else fitted theirs and found this to be the case?
I will take some photos and a video to show what's happening.
Thanks for your comment.
I never had any problems with the main core/tube. Bit of double tape should stop them from any moves.
Don't worry you can return them if you are not happy with the quality.
From memory mine were snug fit at the front and very slack at the rear. I had one of the origional extrusions before the end clips were produced so I had to cut the ends and use the origional VW end clips. They took a lot of modification to sit right.
Surely taping them down will cause problems, because with them being loose dirt will find its way down the sides, these will then need removing to clean out the channel?
I reckon driving on the motorway these would easily blow out. Strange as one side is tighter than the other. The originals were far far tighter than these and were actually quite awkward to remove with them being so tight.
It seams to me that one side is to long and required some additional work to be done.
Try to remove this small end clip that should give more room for the core to sit down then we will know what is the problem.
Or there might be to much of the old tape underneath that push it up.
Let me know how you get on so I can help you.
