Northendroid 10 Posted September 17, 2016 (edited) Bought the car a few months ago for father/son project, car has a knock, body is pretty solid nothing rust thru. Looked into cylinders with borescope, found no marking on the piston, compression test 150 psi across all cylinders. Verified timing the camshaft sprocket was out by two teeth. Forgot to mention that oil idiot light comes on as well. No bottom end work was done. Which is why I've decided to pull the engine out and go through all of it. Not trusting any work that the PO did, reason the head was rebuilt is because someone told him that this would fix his misfiring issue, turn out to be distributor (no kiding Einstein). I'm suspecting rod bearing, I'll post some pictures when I've got it torn apart. One bonus item the PO gave me is the VW Factory Repair Manual :D Edited September 17, 2016 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted September 17, 2016 Bit of progress today, got the car up on jacks, tagged the wiring, removed the front end. Rad support has a bit of rust but will clean up nicely. Quote Share this post Link to post Share on other sites
johnnycr2002 10 Posted September 17, 2016 Enviado desde mi iPad utilizando Tapatalk Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted September 17, 2016 Let me Know if you need any g60 bits.. Quote Share this post Link to post Share on other sites
Northendroid 10 Posted September 17, 2016 (edited) Let me Know if you need any g60 bits.. Thanks I'm in need of the lower front bumper grill and the boost pipe the one with the CO Pot. Edited September 17, 2016 by Northendroid Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted September 18, 2016 Ok mate, i'll check. Quote Share this post Link to post Share on other sites
Northendroid 10 Posted September 18, 2016 Slowly started ordering replacement parts: New belt tensioner dampener, previous owner (below) solution to adding more tension: Replacing the plastic coolant flanges with casted aluminum ones: Replacing all of the motor mounts since looks like there the original mounts: Replacing the front one with a billet solid mount: Quote Share this post Link to post Share on other sites
johnnycr2002 10 Posted September 19, 2016 🖒 Sent from my SM-G930P using Tapatalk Quote Share this post Link to post Share on other sites
Northendroid 10 Posted September 19, 2016 Well the engine out and on the engine stand. Button up the loose ends tomorrow since my schedule at work got change and won't be coming back for two months. Quote Share this post Link to post Share on other sites
Jim 2 Posted September 20, 2016 Great work :) Nice to see a car that was starting to teeter on the edge of getting scrapped, is getting saved. Keep the updates coming.. always love to read a build / rebuild thread! Quote Share this post Link to post Share on other sites
Northendroid 10 Posted October 20, 2016 Picked up a G60 68mm Autotech pulley and a water pump pulley from a Vortex member in Ottawa (my backyard), well turn out I found G60 heaven. This guy is an engineer and a G60 enthusiast, has his own personal stash of G60 engines and parts tucked behind his automotive parts manufacturing warehouse. I know that there are better engine than the G60, but the uniqueness (which is the attraction for me, everyone else does the engine swap) of this setup is taking what works G60 (when properly maintained) and making it better with more flow through the engine (16 or 20 valve head). Tried to work out a deal on this 20V. G60 that he built for a customer and bought it back. But unfortunately it's not for sale was his first build for a customer and kind of sentimental about keeping it. He also has 4 brand new AEB blocked for a very reasonable price plus tons of other parts, he's also a Mahle piston distributor. One stop shop for G60 parts LOL! Quote Share this post Link to post Share on other sites
Northendroid 10 Posted October 20, 2016 (edited) Bought two brand new (0-Kms) AEB blocks (not the one in the photo LOL) with the crankshaft and intermittent shaft installed in them. One will be to rebuild the PG engine, stock rods and piston will fit in the AEB block, a AEG head gasket is required to fit the PG 8v head, a hole is drill thru the block at one of the thread bolt holes for the G60 oil return and were good to go. Edit: Oh and forgot a ABA oil filter stand off bracket. Second block is for a 20V. 1.8L G60 build. Also purchased a DRS oil pan for this build. Edited October 20, 2016 by Northendroid Quote Share this post Link to post Share on other sites
Jim 2 Posted October 20, 2016 Talk about a stroke of luck, finding someone so knowledgable about G60's so nearby. Result! Quote Share this post Link to post Share on other sites
Northendroid 10 Posted October 20, 2016 Yeah you bet had to pinch myself LOL, in my backyard. You expect and see this in California not in Ottawa! His name is Issam Abed also his user name on Vortex his got some great threads in the G60 forum section worth the read! Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 2, 2016 I couldn't resist came across this on Facebook this morning, thought it was fitting so I ordered one LOL Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 3, 2016 I like that , I will have to get one myself. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted November 3, 2016 I couldn't resist came across this on Facebook this morning, thought it was fitting so I ordered one LOL Can you post a link to it please, maybe get my wife to order me one for Xmas? Ian. Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 3, 2016 (edited) Here you go: https://teechip.com/n-e-v-e-r--u-n-d-e-r-e-s-t-i-m-a-t-e--volkswagen#id=4&c=161616&sid=gildan-50-50-hoodie&s=back Only available till Nov. 5th 2016! Edited November 3, 2016 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 9, 2016 've found a used AEB head for cheap for my 1.8L 20V G60 build, so going to have a look at it next Sunday when I get back from work. Only draw back it's a 5hr drive from home, but if it works out be worth the drive. Planning on rebuilding it since price is right, seller sent some pics: Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 9, 2016 Also found in the same area as the AEB head, a BBM Stage 4 chip, FPR, 265/260 cam for the PG rebuild. So well worth the trip Quote Share this post Link to post Share on other sites
odub 0 Posted November 9, 2016 I'm watching with interest to see what results you get from this setup. Not massively relevant but I'm going to be running an AEB in mine but with a K04 turbo Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 9, 2016 (edited) I'm watching with interest to see what results you get from this setup. Not massively relevant but I'm going to be running an AEB in mine but with a K04 turbo Nice! I'm keeping the G60 just for the uniqueness of the supercharger, so will be rebuilding it regularly since I'll be running a 68mm pulley. Are you going to keep the Digi 1 or standalone? Edited November 9, 2016 by Northendroid Quote Share this post Link to post Share on other sites
odub 0 Posted November 10, 2016 going to be running the standard ecu that came with the 20vt engine and loom for the time being Quote Share this post Link to post Share on other sites
Northendroid 10 Posted November 11, 2016 (edited) Pick up my parts in Ottawa today, two AEB block, DRS oil pan, AEB valve cover, header for the AEB head. He also has a brand new AEB head that I'm try to work a deal on. One of the blocks is going to be used to replace the PG block all of the internals piston, conrods, oil pump and distributor fit on the AEB block, a few mods are required for the g-lader oil return, g-ladder mounting bracket needs custom plate, turbo oil supply blocked and a AEG head gasket to fit the 8V head to the block, head gasket also seals off three oil journals that aren't used with this head. Second block for a 1.8L 20V G60 build. Edited November 11, 2016 by Northendroid Quote Share this post Link to post Share on other sites
