plateletboy
Nearside door bits - Window Reg/Motor; trims; seals; rubbing strip
Nearside (L) door bits off a 1994 VR6.
Window regulator and motor; moves smoothly when I put power to it
Inner window black plastic trims
Outer window black upper rubber seal
Door rubbing strip
Happy for the trim bits to just be made use of, so just postage costs.
Want something for the motor/regulator.
Thanks,
murray
yeah sure. So to be sure they are the black plastic bits that you see at the top between the door card and window. one inner you can't see, and the outer one you can.
How about £10 delivered..? Do you want some photies?
thanks,
murray
thanks,
murray
That sounds fine mate, no pictures required, just let me know your PayPal and I'll send the money over.
Thanks
Martin
