plateletboy 0 Posted October 8, 2016 Nearside (L) door bits off a 1994 VR6. Window regulator and motor; moves smoothly when I put power to it Inner window black plastic trims Outer window black upper rubber seal Door rubbing strip Happy for the trim bits to just be made use of, so just postage costs. Want something for the motor/regulator. Thanks, murray Quote Share this post Link to post Share on other sites
easypops 8 Posted October 8, 2016 Interested in just the trim bits if that's ok? Quote Share this post Link to post Share on other sites
plateletboy 0 Posted October 12, 2016 yeah sure. So to be sure they are the black plastic bits that you see at the top between the door card and window. one inner you can't see, and the outer one you can. How about £10 delivered..? Do you want some photies? thanks, murray Quote Share this post Link to post Share on other sites
easypops 8 Posted October 12, 2016 yeah sure. So to be sure they are the black plastic bits that you see at the top between the door card and window. one inner you can't see, and the outer one you can. How about £10 delivered..? Do you want some photies? thanks, murray That sounds fine mate, no pictures required, just let me know your PayPal and I'll send the money over. Thanks Martin Quote Share this post Link to post Share on other sites
