lilfuzzer
Early G60 list page 1
Hi all I bought what was left from a mostly broken g60 a while ago. but now need to make room so rest of the car needs to go. many parts already removed just needs finishing. Also if anyone wants panels cut out please just ask.
Car had aircon (retro fitted) but useful for bits
I'll run this like the last couple of breaking threads and let people enquire for parts until I finish the full list.
I've collected parts for nearly 20 years from all types of cars so please ask if you need anything else.
Location is Bishop Auckland but happy to post parts if they can be.
Thanks for looking,
Chris
[TABLE=width: 467]
[TR]
[TD]Brake servo and master cylinder[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Power steering bottle[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Clutch master cylinder and pipe[/TD]
[TD]25[/TD]
[/TR]
[TR]
[TD]Lower engine heat shield[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Black interior light 4 pin[/TD]
[TD]sold have others[/TD]
[/TR]
[TR]
[TD]passenger dash undertray grey[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]drivers dash undertray grey[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]fusebox cover grey[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]parcel shelf one strap missing[/TD]
[TD]sold[/TD]
[/TR]
[TR]
[TD]Arch liner[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]drivers side kick tray grey[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]pair grey speaker shelf supports[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Splitter bar[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]rear ashtray grey[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]gear gear surround[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]passenger grey kick tray[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Boot trim lock surround grey[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]early sunroof switch[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]early sunroof switch surround[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]fusebox metal hanger[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]centre windscreen trim one bit missing[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Pass side windscreen trim[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Boot seal[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Parcel shelf supports grey drivers fine but pass has nicks[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Black bonnets brackets[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Pass headlight with reflector no glass one clip missing[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Shifter box and cables[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]Speedo loom[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Headlight loom[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Fog switches loom[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Brake duct 535 145 937A[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]15[/TD]
[/TR]
[TR]
[TD]Airbox ducts x 4[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Clocks mmileage unknown[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Handbrake handle[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Clutch rest plate grey[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Pair seat runners[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Brake duct with sensor 535 805 876[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]between c pillar trim[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]leather steering wheel leather ripped[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]grey carpet one split under seat otherwise good condition couple of tears under door trim[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]Speedo surround[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]pair rear door cards grey[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]rear strut tower caps x2[/TD]
[TD]3[/TD]
[/TR]
[TR]
[TD]boot carpet full size spare grey[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]boot carpet sace saver grey[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]pair grey b pillars[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]pair grey a pillars has alarm holes[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Pair c pillars grey[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]centre tunnel top and bottom all tabs in tact hump version[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]rear grey seats with hump[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]pair sunvisors[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]early adjustable steering column[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]Inner sunroof surround[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]set of seat belts[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]pair of seat belt bars[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]pair rear seat belt buckles[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Exhaust with homemade decat[/TD]
[TD]50[/TD]
[/TR]
[TR]
[TD]front subframe with steering rack and hubs (no brakes)[/TD]
[TD]40[/TD]
[/TR]
[TR]
[TD]Fuel Tank[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]headlining a bit of material coming off front pass corner[/TD]
[TD]40[/TD]
[/TR]
[TR]
[TD]sunroof mech (still to be tested)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]rear view mirror[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]grey front centre tunnel x 2[/TD]
[TD]5 each[/TD]
[/TR]
[TR]
[TD]pair rear seat foam[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]early steering stalks pair with MFA wire[/TD]
[TD]25[/TD]
[/TR]
[TR]
[TD]gear gaitor and surround[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]radiator cover[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]number plate light and surround good nick[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Ignition loom[/TD]
[TD]20[/TD]
[/TR]
[/TABLE]
Edited by lilfuzzer
Hi Dave have loads of interior left will get pics off drivers wing and door
Sent from my SM-G357FZ using Tapatalk
  Thursdave said:
Corking! :D What colour are the interior plastics?
Hi mate the colour is black
the wing and door has very little rust and actually very good. There is unfortunately a lot of scratches so will need painting anyway on the wing certainly and unsure on door.
Will get pics for you though as very bad light at minute
The wiring, box itself, pipes but one is cut and the condenser will get some pics for you mate
I'll be honest mate never used or fitted one before so really don't know I would guess one pipe and radiator panel
  lilfuzzer said:
yeah pal thats there there was a button on teh dash
So do you reckon it was a retro fit from a different car ? I'd be interested if it was an oe Corrado setup
803071d85d8731f2274892843c44b4e7.jpg3f31d0573c058714ae9facd5070d7ee2.jpg8dc3b4e5573d77f3504fd21b0c69e648.jpg0de48eba2b641a8eac93c921ad1fa42a.jpg896a910484c6b1e6440c1616da90362c.jpg
Door is no good as has bit dint
Balls, shame about the door.
Wing looks good though - i can fix that little bit of rust easy enough.
What you thinking of for it? also need the drivers footrest that goes behind the bonnet handle
Hi mate the wing is 50 pounds
I have the foot rest for you too. 15 for black or 10 for grey
Did it have electric windows ? I could be interested in a pair of door looms as well
  lilfuzzer said:
Yeah pal it did and door looms available no bother
Ok so far my list would be:
1. Tailgate side trims & parcelshelf hanger screws
2. Door looms
3. Dash vents ( centre and near side)
4. Air-con setup ( maybe)
2. Door looms
Sound mate they all have your name on
