Robbo149 0 Posted July 12, 2004 Hi all, I had my clocks apart at the weekend to fix my temp gauge (which now works, cheers Henny), but now, on the way to work this morning I got no reading on the oil temp, just the 3 dashes! Everything else on the MFA works fine. Could I have done something when I had the clocks out? It was fine last week. Or is it just another 'Christine' type coincidence? Cheers, Robbo Quote Share this post Link to post Share on other sites
Henny 0 Posted July 12, 2004 Check the multi-plug on the back of the clocks is fully in, it's possible that it's just a cruddy contact causing the problem... :roll: Quote Share this post Link to post Share on other sites
Sanj 0 Posted July 13, 2004 I have this same prob on mine, but mine started to happen after I cahnged the oil in a service. Any advice anyone?? Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2004 Sanj, Check the wiring to the sender and if it's OK, then put in a new temp sender, odds are either the sender of the connection's died... 8) Quote Share this post Link to post Share on other sites
Robbo149 0 Posted July 21, 2004 Right again Henny :) you C-God! (My fuel gauge packed up too, btw!) I hadn't pushed the multiplug in all the way, it seems it needs a good firm push until it clicks in properly :oops: Cheers again, Robbo Quote Share this post Link to post Share on other sites
