Robbo149
Oil temp on MFA - no reading
Hi all,
I had my clocks apart at the weekend to fix my temp gauge (which now works, cheers Henny), but now, on the way to work this morning I got no reading on the oil temp, just the 3 dashes! Everything else on the MFA works fine. Could I have done something when I had the clocks out? It was fine last week. Or is it just another 'Christine' type coincidence?
Cheers,
Robbo
Check the multi-plug on the back of the clocks is fully in, it's possible that it's just a cruddy contact causing the problem... :roll:
I have this same prob on mine, but mine started to happen after I cahnged the oil in a service. Any advice anyone??
Sanj, Check the wiring to the sender and if it's OK, then put in a new temp sender, odds are either the sender of the connection's died... 8)
Right again Henny :) you C-God! (My fuel gauge packed up too, btw!) I hadn't pushed the multiplug in all the way, it seems it needs a good firm push until it clicks in properly :oops:
Cheers again,
Robbo
