jackswan2013 10 Posted December 21, 2016 Just scanned for electrical faults came up with air flow meter and speed sensor, just wondering what is the correct voltage for each sensor as a precautionary measure. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted December 21, 2016 Just scanned for electrical faults came up with air flow meter and speed sensor, just wondering what is the correct voltage for each sensor as a precautionary measure. Sent from my iPhone using Tapatalk If you're talking about the engine speed sensor then if youve scanned the car with the engine turned off you will always get that code. Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 22, 2016 (edited) As Dox says . In my opinion these rarely go wrong, despite the vulnerable position (crank sensor , speed sensor) . Unless the engine is running it will always come up with the fault . If you want to test it , have a look in the search and you will find the correct voltage. I don't have my manual to hand ATM . Edit . If you search on google , correct voltage for Corrado crank sensor, the first answer is there . From Mr Gaskil who was a legend on this forum. Edited December 22, 2016 by robrado974 Quote Share this post Link to post Share on other sites
