Tabbi 10 Posted January 14, 2017 Hi guys, i have a problem with my speedo not working along with the spoiler which does not raise at speed. It does work manually off the switch. I found the 10A fuse was blown so replaced it and all was good. Took it on the bypass, spoiler came up at correct speed and then as i slowed down at the roundabout and spoiler started to retract the car cut out...... Speedo stopped working.... Fuse blown again. Any ideas on why that is....?? Quote Share this post Link to post Share on other sites
Jim 2 Posted January 14, 2017 Most likely the mechanism needs removing and cleaning. It could be gummed up with muck which is putting additional strain on the motor, causing the fuse to pop. Quote Share this post Link to post Share on other sites
dragon green 6 Posted January 14, 2017 Here you go http://the-corrado.net/showthread.php?t=51125 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Tabbi 10 Posted January 14, 2017 Ok great. Will give the mechanism a good clean and lube. Appreciate your help gents. Thankyou. Quote Share this post Link to post Share on other sites
