carrots 1 Posted February 1, 2017 Hi any tips on changing the fuse box Quote Share this post Link to post Share on other sites
Jim 2 Posted February 1, 2017 Disconnect the battery first? Quote Share this post Link to post Share on other sites
Cressa 45 Posted February 1, 2017 Should be Easier than you think as the main plugs only fit in certain places. There is a locking tab on the RH side which clicks out so you can release the plugs. Take lots of pictures and there are plenty of layout drawings on this forum to see where this should go. But good luck. And take the drivers seat out. . Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
carrots 1 Posted February 1, 2017 cheers i just hope the weathers on my side sunday. Quote Share this post Link to post Share on other sites
Geeba 0 Posted February 1, 2017 Just curious.. why does it need replacing? Quote Share this post Link to post Share on other sites
carrots 1 Posted February 1, 2017 i had a problem with number 18 relay getting so hot it melted the fuse box .i dont no if its a bad earth that caused it or the relay not fitting very tight in fuse box. Quote Share this post Link to post Share on other sites
