carrots 1 Posted February 22, 2017 Got home this morning went to turn lights off and couldn't so I removed the switch.if I shake it there's something inside broken off, so is it dead.i am sure I've got a spare I bought about 7 years ago.its an early switch Quote Share this post Link to post Share on other sites
MZpog 10 Posted February 22, 2017 (edited) Early/late switches are interchangeable but both break inside. I changed to one of the aftermarket ones sold on here (8vMatt) and would wholly recommend them if you can't find your spare. Edited February 22, 2017 by MZpog Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted February 22, 2017 as MZpog said, gets yourself a new one from here they use an LED so will not suffer from the same failure as the OE ones, where the heat from the lamp causes the plastic to go brittle inside Quote Share this post Link to post Share on other sites
vagstuff 13 Posted February 22, 2017 g0ldf1ng3r said: as MZpog said, gets yourself a new one from here they use an LED so will not suffer from the same failure as the OE ones, where the heat from the lamp causes the plastic to go brittle inside .. and another endorsement from me for 8vMatt's switches... here's the Link to his latest batch : http://the-corrado.net/showthread.php?96213-2017-Headlight-Switch-group-buy-is-a-go! Quote Share this post Link to post Share on other sites
carrots 1 Posted February 22, 2017 Cheers for that I will get one sometime it's having surgery on the brakes end of month and that's costing a lot Quote Share this post Link to post Share on other sites
