Jim Bowen 1 Posted April 10, 2017 While i was doing the timing on an engine i thought i'd take some pics to show the various timing marks etc (using a bit of advice from Vince at Stealth racing) I wasn't replacing the lower chain this time but can show what you want to achieve when timing the bottom end. Mark on the pulley, i stick some tape to the outside of pulley to make it easier to see quickly when turning it. First thing to note is the ground tooth on the crank sprocket If you look closely there is one tooth that has been ground so its different from all the others. This will want to line up with the seam on the block. On the intermediate sprocket there is an arrow, and you want that pointing vertically up, i found for each complete turn of the crank pully this arrow will move 90 degrees, so you may have to turn the crank a few turns. I had no cams in the engine at this point, but if cams are installed you will probably hit them with the pistons Another bit to note (this is what Vince told me), once you think the intermediate marking is lined up, check from above that you can see the little notch in the plastic, if you don't see this keep turning crank pulley until the sprocket mark is vertical and you can see the notch from above Cam want fitting so the smaller lobe is on top, the cam locking tool only fits one way anyway Once your at this point, i find it easiest to leave one cam sprocket off, fit the upper tensioner, drop the chain in to intermediate sprocket and one cam sprocket, and then fit the other cam sprocket to chain and then push it onto the cam, after all in place i then fit the black plastic guide. All fitted Nice way to lock the crank when using an engine stand After all is fitted, fit the upper chain cover and tensioner bolt and then turn crank pulley 4 complete turns and all the marks should end up where they were. Quote Share this post Link to post Share on other sites
culshaw 1 Posted April 21, 2017 Is that really all it takes?, I've always thought it's a real tough job and requires some esoteric knowledge only passed between engine builders from the planet zog. Great post Sent from my Nexus 5X using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted April 21, 2017 Its nice and straightforward when the engine is out - as this brilliant thread and pics show. Great info Jim thanks for the details. I did mine when i took the block out but rechecked the timing with it in situ - which wasn't so easy.. Its just the time required to take it all out though Quote Share this post Link to post Share on other sites
Geeba 0 Posted October 4, 2017 Just about to look at getting my block back from the engine builders so need to look at chains.... Since the parts are obsolete from the main Stealers... and I flatly refuse to give VW Teeside http://vwgolfr32.co.uk/shop/VR6-Timing.htm - £377 for a kit that was £150.. can anyone recommend or advise which parts they have used? I can only find the Fibi Bilstein kits which don't have the revised non-rivited parts. Quote Share this post Link to post Share on other sites
Dox 31 Posted October 4, 2017 Thursdave on here works for VW in the parts dept. Ford used the VR6 in the Galaxy (shared platform with Sharan and Alhambra - Merc in the Vito too), so there's another outlet to try for bits Quote Share this post Link to post Share on other sites
Geeba 0 Posted October 5, 2017 Morning Dox, yeah I did wonder that... I really wanted the revised non-rivited parts... problem is the first thing they ask for is a Reg or chassis number. Quote Share this post Link to post Share on other sites
Jim 2 Posted October 5, 2017 Could you look for a Galaxy VR6 for sale on Autotrader or similar, and just use the number plate from that to give to the dealer? :) Quote Share this post Link to post Share on other sites
Dox 31 Posted October 5, 2017 Geeba said: Morning Dox, yeah I did wonder that... I really wanted the revised non-rivited parts... problem is the first thing they ask for is a Reg or chassis number. Ford dealers sell old stock on ebay with pictures and full spec on listings. Galaxy 12v v6 - they tend not to use VR6. I've bought chain guides a few years ago and 4 out of 6 sexy red plug leads lol (£8-£10 each) Quote Share this post Link to post Share on other sites
Dox 31 Posted October 5, 2017 https://www.fordpartsuk.com/ I think it was their ebay shop I got my bits from Quote Share this post Link to post Share on other sites
