cmck32
Coolant
Can anyone tell me if this coolant is good suitable 4 a 94 vr6 corrado???cae70b88dff3489b3a4af02732b0d402.jpg
Honestly never heard of it before. I'd highly recommend just picking up the current standard VW coolant from any VW parts department... is it G13+ currently?
Can see that...... Its a summer anti-freeze, so won't have an all year round temperature range - therefore very unlikely to the correct VW spec. The G13+ coolant is pretty cheap from the dealer (about £10 for the 1.5 litre bottle iirc), so its worth just using that as you know the anti-corrosive properties are correct as well, and it'll last you a couple of years before you have to do it again.
I'd never mix antifreeze as it can turn to jelly, I always flush before changing to minimise problems
I had it flushed out cos I was changing the radiator
You're not going to get a 50% mix with 1L of antifreeze, not even 30%?
I had 3litres of it
I'd use it then
Also when changing the radiator putting new coolant in!!! Would anyone give advice on changing the fan relay module??
It was over heating and radiator wasn't coming on!! Radiator was buggered so changed that and now jus need to top up with coolant and try again
I checked that and I also think I'm missing this sensor but there is no aircon in my car
Yes. That's a 3 phase controller. You should have 3 sensors. Is there a loose plug near your other 2 senors?
Also is it a uk car?
