spen 0 Posted May 23, 2017 Bought the VR over a year ago with many problems including no working spoiler. Managed to get a new motor as I thought I would try that first and boom it worked fine from there on, raised and lowered at the correct speeds. Had an Auto-electrician guy around to strip out the alarm/immobiliser it had, as because it wasn't getting used ran the battery down. Now it doesn't raise at speed, work's fine on the manual cleaning switch under the dash just not at speed. The auto-electrician guy said change the module which I have and no difference? The VR was originally auto then changed to manual by stealth if that would make any difference? Obviously checked the fuse, I'm really a bit lost on what to do next? Any help much appreciated gents. Quote Share this post Link to post Share on other sites
spen 0 Posted June 13, 2017 Bump Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted June 13, 2017 sounds like the speed sensor feed has been disconnected/chopped during the strip out. Quote Share this post Link to post Share on other sites
spen 0 Posted June 14, 2017 Thanks Tigerfish for the input, think I may need a Bentley manual to help, turning out to be a real 'puffer fish' of a job! Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted June 14, 2017 On my Corrado, part of the alarm (the box that feeds the motion sensors) was stuck to the spoiler control module with double sided tape. Sits behind dash near where manual spoiler switch is located. May have been disturbed when removing old alarm. Quote Share this post Link to post Share on other sites
spen 0 Posted June 16, 2017 Yeah Jamo, these install standards of alarms in the 90's are shocking, i think the speed sensor's are still available from GSF where are they located exactly? Under dash or tailgate? or neither! Quote Share this post Link to post Share on other sites
