Cressa 44 Posted June 28, 2017 Got mine off the car and was wondering what people use to put some colour and life back in them. I would like to keep them oem looking, but fresher Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 28, 2017 Perhaps should have been in car care section but can't seem to change it. .oops Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted June 28, 2017 You could give them a rub down as a key then primer plus satin black paint - Should last then? Ian. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 28, 2017 Ive used this http://www.theultimatefinish.co.uk/gtechniq/c4-permanent-trim-restorer.aspx?utm_source=Google&utm_medium=shopping&utm_campaign=MerchantCentre&variant=4639&gclid=EAIaIQobChMIhe3clNDh1AIVpLDtCh1vdQypEAQYASABEgL7YPD_BwE Seems to last very well Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2017 good question cressa i too will be doing similar & was thinking as per sean's suggestion for the roof rails but am unsure on the door handles previous stuff ive used on them always fades very quickly, worth a look at stuarts link methinks FYI i have been using that gummi stuff that has been mentioned on here on my window rubbers & it seems to be bringing them back nicely so far cressa - are you replacing he door handle gaskets or did you manage to remove the handle without breaking them? Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 29, 2017 Gaskets were fine fortunately. I like the idea of the g4 stuff as it sounds easy, but one of my door handles has chipped so needs covering better. I may try the spray method on something first. I'll look at that gummi stuff as I need something, cheers Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Geeba 0 Posted June 29, 2017 Hmmm yeah that C4 looks pretty good! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2017 Hmmm yeah that C4 looks pretty good! indeed it does - just watched the video im going to order some & give it a go :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2017 Gaskets were fine fortunately. I like the idea of the g4 stuff as it sounds easy, but one of my door handles has chipped so needs covering better. I may try the spray method on something first. I'll look at that gummi stuff as I need something, cheers Cressa Sent from my SM-G900F using Tapatalk tidy - hope i can get my gasket off ok too linky for bummi - http://www.ebay.co.uk/itm/Nextzett-Gummi-Pflege-Flege-Car-Rubber-Stick-Door-Restorer-100ml-/162516660510?epid=1005414647&hash=item25d6bf711e:g:ar4AAOSw32lYwD4A Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 29, 2017 I found the G4 best applied a couple of times a week or two apart, if you put it on too thick it runs and drips (its too expensive to waste)and dries a little opaque. Quote Share this post Link to post Share on other sites
Cressa 44 Posted August 8, 2017 So I used the C4 stuff. Very impressive really. The parts had to be washed first, then some panel cleaner, then the C4. The side trims which looked alright look great. The door handles hands needed a couple of layers but do look better The roof trim is work in progress. ... I was going to paint the door handles but am glad I decided against, as they seem to be a hard plastic. I was worried my paint skills wouldn't take to it. If the roof trim doesn't come good I shall look to paint it. Just unsure of how to prep it and which paint to use. .. Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 9, 2017 Looks good. I think even with the G4 stuff the key is in the preparation before you apply it - otherwise it won't last and it's expensive juice! Quote Share this post Link to post Share on other sites
