graham1971 10 Posted July 12, 2017 I have a yellow wire with a black stripe in a black sleeve loose in my engine bay. The other end disappears into the wiring loom lower down. See pictures. The wire has a blade type connector on the open end and I can't locate any obvious connectors without a wire attached? The first picture is the wire end and connector, the second is where it disappears into the loom behind the silicon hose. The only electrical problem I'm aware of is that the alternator only appears to charge the battery when the car is driving, not while it's idling. Any ideas? Sent from my Pixel using Tapatalk Quote Share this post Link to post Share on other sites
graham1971 10 Posted July 12, 2017 Ok, I think I just found an old thread about the same wire being a spare one for Aircon to be fitted. Problem solved unless someone can say differently? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 12, 2017 Yeah, its normal, i have the same thing, am sure i also had it when i had aircon. I thought it was to do with adding the voltmeter VDO thing. Also what radiator is that? Quote Share this post Link to post Share on other sites
graham1971 10 Posted July 12, 2017 It's an upgrade one I had made by a German company because all the aftermarket stuff I could find seemed to be really poor build quality. Sent from my Pixel using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 12, 2017 Looks solid enough. I noticed the other day that my vw replacement is starting to leak so going to be looking for a new one soon. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 13, 2017 It's for oil pressure to VDO gauges, just pop it out of the way in case you ever get them fitted Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 13, 2017 Vag-hag, where did you find the other end of that wire? Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 13, 2017 Right by the fuse box. Yellow single female connector from (****e) memory :lol: Quote Share this post Link to post Share on other sites
