Kevin Bacon
Ground loop noise
Any of you guys use a Ground Loop isolator?
I'm picking up some interference from the Alternator (I think) and I really can't be arsed to pull the wiring out again, so would an isolator get rid of it?
Cheers
K
interested in this myself as I've just started to get some noise myself and it's very irritating to me.... (most people can't hear it :roll: )
Yep it's annoying for sure! I've done several installs in VWs and never had a noise issue, until now. Why is nothing ever simple on bloody Corrados?
I think Halfords sell these isolators (it's just a big inductance loop) so might try one this eve.
have you checked the noise supressor in the altenator is ok?
I had bad noise on my stereo till i changed the brushes on my alternator, now im 99% sure the noise supressor is the other little wired on thing on the alternator. Change them both, the brushes only cost a around 5 quid iirc.
If you are running an amp you should have it earthed back to the battery via a low impeadance wire, if not try running the earth back to the battery, not the chassis earth point in the boot.
Also have the same problem, the cursed accelerator whine! Will try running a wire from the amp to battery at lunch, see if that solves it. Have heard mixed reviews on the isolators, one way to find out!
ta
randal
ta
randal
On papaer, that wont fix it. Ground loop is a fixed hum that is a result of two different grounds, in the same system being at different potentials.
The changing hum, reletive to engine speed, is a result of an AC componented frequency, sitting on the 13v DC level. You need to block the AC components, which is what the induction loop does. The altenator has an induction looop built in, but these can degrade with time. As G60Jet rightly says, it is about £5 for brushes, and same again for the noise supressor.
That said, u know what its like with raddos.......the wire will probably fix it! lol
This is all good info, keep it coming !
Thinking about it, I think my noise is more a clicking than a whine, it's sort of engine speed related but doesn't really change pitch too much. I don't get any pops and clicks when putting the wipers on etc, so I'm wondering if it's ignition noise I'm picking up?
If it is then the induction loop won't remove it as it's digital pulsing on the VR, not a cyclic AC output like an alternator...... arse.....
I might still try the induction loop though as they're only a tenner.
You're right about the amp's earth going to the battery, it makes no difference but earthing at a shared cluster of earths (star earth?) sometimes helps.
andycowuk, on paper your dead right, apart from one thing, a car only has one ground, earthing the amp directly to the battery will isolate any electrical noise from other equipment.
And there is one more thing, there isn't enough room on my battery terminal for another large connector!
To put you more in the picture, the amp is bolted to the back seat and is earthed to one of the seat back's retaining nuts.
All the cables run down the passenger side of the car.
I've done this numerous times in MK2s and MK1s etc with no noise. And the Corrado would have to go and change all that!
What probably hasn't helped my cause though is bunching up the excess RCA lead into a bunch and tie wrapped it behind the dash! Although I've done that before too with no adverse effects........
Kev Iáve got an RCA that a meter or two longer than it need it in my c so all the excess is floating around in the rear bench. Having the amp earth to the seat bolts is not the best of ideas considering there is an earth point behind the rear quater trim card where the window controller is and there is another in the boot for the lights (i wouldn´t use the light earth point though, you MAY get a click click every time you use your indicator
No, it wont if the noise is on the power supply, and not on the earth - ie coming from the altenator.
Nige, that was the nearest earth point to the amp and is solid. I'll figure it all out tonight and solve it.
And whilst on the subject of ICE. What's a non-fading fader thingy? Now that the Pioneer is running the amp, a few more options have appeared in the menu system. One of them is NonFading on/off. When it's off, it produces a really bizarre sound. It's sounds lovely, almost live but at reduced volume on zero balance. If I balance over to the left or right, sound still comes out of the faded out speaker!
When nonFading is set to on, the L & R orientation is reversed but the sound is louder. I don't get it. The orientation on the RCAs and speakers is most definitely correct.
Confused...... :(
OK, picked up a couple of isolators from Halfords (Autoleads) and there's no instructions with them. Do they go at the head unit end or the amp end??
Cheers
Kev the seat bolt will earth but not that well, especially if its painted or grease as some of them are on mine
Cheers
Kev, how much did they set you back?
Nige, where's the best place to earth at the back? There's something rattling behind the rear card actually, so is in there a good place to earth?
Randal, they're were £15 each mate. I needed two unfortunately as it's a 4 channel amp :cry:
Kev, I've used them before with alternator whine and it didn't fix it.
In the end I rewired it all (better cable, earths etc) and that fixed it (without fitting the isolators)
gl though mate, its a very annoying noise when you have it, especially as Henny says, when you seem to be the only one that can hear it.
Hmmm, shame you didn't post that earlier before I bought the darn things! Nevermind!
I've used expensive RCA leads and all the connections are soldered, so maybe it's the earth point I chose?
Unlike Henny's noise, mine is very loud and you'd have to be deaf not to hear it!
It's a constant volume too, doesn't get any louder and is engine speed related, so gotta be the alty. Although it doesn't whine as such, but ticks....
Bummer me too! Although from what peeps are saying that's probably not going to help. Looks like it's a strip out, and run down the centre tunnel job for the cables. Wooop. :mad:
Ta!
randal
I think the same fate awaits me, too :x
I can guarantee if you just draped the cables on the floor loosely to test it, it would be silent. As soon as you shove em under the carpet and put all the trims back on, the Alternator noise kicks in!
Typical 'Corrado' factor! In a MK2 you could earth the amps to an Apple and wrap the RCAs around the alternator and it would still be silent.....
You might be picking up noise from the bunch of cables under the dash - try coiling them in a figure of 8.
Good point. They're bunched up next to a load of relays above the heater fan. I'll try moving them to down the transmission tunnel this evening and bunch the slack up at the rear of the car instead. Or better still, cut the excess slack away and reterminate the phonos.
All fun and games eh? I hate doing the same job more than once......grrrrr!
K
The RCA cables will be too close to a power source just experiment with there placement and your sure to cure it without messing with ground loop isolators and suppressors and such, make sure the RCAs arent running alongside the power cables for the amp is a good start :lol: and the figure of 8 someone mentioned earlier also helps some.
LMAO, sod's law on that one. I may be in a different boat to you though, as I managed to carry the whine over from a previous install using the same amp. Maybe a fault actually within it....? Anyone want to donate me an amp for.. err.. "testing"? :lol:
