Tjninny
Switch or motor?
Hi all,
My sunroof slides back but will not close or tilt unless I use the Allen key - before I buy a mk3 golf motor, anyone got any advice or info as to what. The fault might be?
Cheers.
From which model Graham or do you have a part number? Why did you swap anyway - how did you know it was the motor?
Thanks.
From memory I think it was a year 2000 Skoda Octavia, I swapped because of the exact problem your describing of the panel opening but having to be retracted by hand. I changed it purely as a process of elimination as I am definitely not an expert.
Sent from my Pixel using Tapatalk
