GrahamV 10 Posted December 4, 2017 (edited) SEE NEWER POST FOR ITEMS STILL LEFT Corrado VR6 original working serviceable Used Parts, a few new items too. Looking to clear remaining parts. All items on a first come basis. First to commit to buy taking precedence over request for further information or photos etc. Items in photos but not listed below are already sold Collection from North Staffordshire near Leek or post at cost. Please request/reply on this thread for me to update list and PM confirmations. Regards Graham V [ATTACH=CONFIG]90509[/ATTACH] [ATTACH=CONFIG]90512[/ATTACH] [ATTACH=CONFIG]90467[/ATTACH] [ATTACH=CONFIG]90539[/ATTACH] [ATTACH=CONFIG]90542[/ATTACH] [ATTACH=CONFIG]90506[/ATTACH] [ATTACH=CONFIG]90545[/ATTACH] [ATTACH=CONFIG]90548[/ATTACH] [ATTACH=CONFIG]90551[/ATTACH] [ATTACH=CONFIG]90569[/ATTACH] [ATTACH=CONFIG]90572[/ATTACH] [ATTACH=CONFIG]90575[/ATTACH] [ATTACH=CONFIG]90578[/ATTACH] [ATTACH=CONFIG]90581[/ATTACH] [ATTACH=CONFIG]90563[/ATTACH] [ATTACH=CONFIG]90455[/ATTACH] [ATTACH=CONFIG]90458[/ATTACH] [ATTACH=CONFIG]90461[/ATTACH] [ATTACH=CONFIG]90494[/ATTACH] [ATTACH=CONFIG]90497[/ATTACH] [ATTACH=CONFIG]90500[/ATTACH] [ATTACH=CONFIG]90464[/ATTACH] [ATTACH=CONFIG]90470[/ATTACH] [ATTACH=CONFIG]90533[/ATTACH] [ATTACH=CONFIG]90485[/ATTACH] [ATTACH=CONFIG]90443[/ATTACH] [ATTACH=CONFIG]90449[/ATTACH] [ATTACH=CONFIG]90554[/ATTACH] [ATTACH=CONFIG]90557[/ATTACH] [ATTACH=CONFIG]90560[/ATTACH] 1 LH Rainwater protector NOS New item NLA item 536 853 829 03C £30.00 1 RH Rainwater protector with all tabs £15.00 1 Centre Rainwater protector with all tabs £20.00 1 Right Indicator MK2 New NOS stored since 1999 Boxed £40.00 near perfect 1 Right Indicator MK2 £20.00 has crack/marked 1 Left Indicator MK2 £25.00 worn but no cracks 1 RH rear Stop Lamp/Indicator Good v small crack £10.00 1 LH rear Stop Lamp/Indicator V Good £15.00 1 LH rear lamp tailgate V Good £10.00 1 RH rear lamp tailgate v Good £10.00 1 Ash tray rear New 32185796101C @£12.00 1 Wishbone Front Lower LH VR6 £10.00 1 Wishbone Front lower RH VR6 £10.00 25 Wheel bolt M12 x 1.5 not vr £8.00set 2 HUB CV Joints Re Finished £8.00 pair- heavy- postage £12 2 Front hubs 5 stud with ABS ring working ok, were corroded now plated & rust free £10.00 pair- heavy- postage £12 1 Servo 9" MK3? golf Golf 7:1 £10.00 1 Clutch blue cloth covered clean feed pipe £2.00 1 Exhaust fits after CAT VR6 MK2 1992 round-good quality £15.00 1 Roof Gutter Rail RH edges frayed £6.00 535853706 01C 1 Roof gutter Rail LH edges frayed £6.00 535853705 01C 1 Roof Gutter Rail hinge cover RH £2.00ea 535853720 01C one tab broken 1 Roof Gutter Rail hinge cover LH £2.00ea 535853719 01C one tab broken 3 Parcel shelf black rubber hangar straps as MK2 golf £3.00ea 1 RH & LH Drop Glass felt lined door frame seals good no tears or scrapes inner pair £30.00 outer pair £50.00 1 LH & RH Door aperture seals good £20.00 pair 2 Screen top cover seal £5.00each 1 LH Outer door drop glass Slot scraper seal £18.00 1 RH Outer door drop glass Slot scraper seal £18.00 1 LH Inner door drop glass felt scraper seal £10.00 1 RH Inner door drop glass felt scraper seal £10.00 1 LH & RH Pair Door glass triangle vertical seal £10.00 pair 1 LH Drop Glass Green tint light scratching £15.00 535845021A 2 RH Drop Glass Green tint light scratching £15.00 535845022A 1 Tailgate glass green tint- 2 filaments need attention £30.00 535845501A 1 Master cyl plastic reservoir no cap NEW Non ABS £10.00 1 Brake master cylinder ABS 23.81mm 4port NEW for Alhambra galaxy sharan but can use with mods £15.00 2 LH door bump protector strip NEW NOS MK1 535 853 515 2BC £15.00ea 2 LH door bump protector strip MK2 NEW 535 853 515A 2BC £46.85 sell £25.00ea 1 LH wing bump protector freshly re textured MK2 £12.00 1 LH door bump protector strip freshly re textured Mk2 £20.00 1 LH rear 1/4 bump Protector freshly re textured MK2 £15.00 1 RH rear 1/4 bump Protector freshly re textured MK2 £15.00 1 RH wing bump protector MK2 freshly re textured £12.00 1 Tailgate lower inner trim black all intact no clips £10.00 1 Bonnet insulation after market thick cut waffle pattern- unused £10.00 1 Bonnet latch Re finished £10.00 1 Bonnet Pin Re finished £10.00 2 Door Striker New £5.00 pair 1 Fuel Filter clamp bracket re finished £3.00 1 Rad top elbow @2.00 1 First aid kit MK1 & Scirrocco NEW in soft red pouch £20.00 1 Warning Triangle 1988-1991 £10.00 1 Heated rear screen dash switch all good £12.00 ea 1 Fog Lamps dash switch all good £15.00 ea 1 Indicator stalk no hazard cowl £8.00 ea 1 MFA Steer wheel stalk £8.00 1 LH Mirror Casing, broken trim (also fits TVR’s) @£15.00 1 set 6 Rear bumper mount body round Clips £10.00 set 1 set Fanfare horns rusty no bracket all ok working fine £10.00 1 set Bumper fixing wedges £5.00 1 set bonnet heated water jets £8.00 2 Door check strap foam seals £1.00 6 Fuel injectors £40.00/set of 6 1 Plug leads set quality 8mm silicone black £15.00 1 RH footwell airvent @£2.00 1 Scuttle water tray seal rubber 535819521 @£5.00 1 Tool kit strap £3.00 1 Gear box mount selector remote plastic £5.00 1 Gear box 1st syncro and others £5.00 1 Power steer reservoir & cap £5.00 Edited January 16, 2018 by GrahamV Update Quote Share this post Link to post Share on other sites
odub 0 Posted December 4, 2017 I'll take the Corrado warning triangle posted please if in good condition. Please pm me your payment details. Thanks, Oli Quote Share this post Link to post Share on other sites
sharpy-vr6 10 Posted December 4, 2017 2HUB CV Joints Re Finished £8.00 pair 2 Front hubs 5 stud with ABS ring working ok, were corroded now plated & rust free £10.00 pair Pictures are not working for me but may be interested in these how much posted? Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
g60knight 0 Posted December 4, 2017 hi buddy will take: 1 Exhaust Sys cat backwards Powerflow £40.00 1 Throttle Body VR6 MK3 3 pin ODB1 £20.00 1 Bonnet insulation after market waffle pattern £15.00 thks Quote Share this post Link to post Share on other sites
Rado87 10 Posted December 4, 2017 I’m would like the bonnet insulation (posted) if it’s in good condition/new. Same as above, can’t see the pics?? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
branty 10 Posted December 4, 2017 (edited) I would like both left and right outer slot seals please posted, 20 each Cheers Edited December 4, 2017 by branty Quote Share this post Link to post Share on other sites
dan 0 Posted December 5, 2017 (edited) Hi mate, I'll take 2 Door end bungs £4.00 pair 1 Rear brake equalizer spring £1.00 1 Tailgate loom rubber @£2.00 10 Body OE aperture seals 40mm* £10 for the lot 1 RH Rainwater scuttle cover no clips £5.00 1 Fan blower motor working £5.00 1 Rear brake equalizer bolt socket head domed £1.00 Let me know what you need to post! Would also like 2nd dibbs on the Powerflow exhaust system, I was actually looking about one of these at the weekend. Thanks P.S. whats your new project? Edited December 5, 2017 by dan Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 Sure its good, will check and photo later and confirm postage by PM odub said: I'll take the Corrado warning triangle posted please if in good condition. Please pm me your payment details. Thanks, Oli Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 Photos sorted now Post is an issue due to weight about £12 per pair =£24 sum! Let me know if you would like them and will then PM etc. sharpy-vr6 said: 2HUB CV Joints Re Finished £8.00 pair 2 Front hubs 5 stud with ABS ring working ok, were corroded now plated & rust free £10.00 pair Pictures are not working for me but may be interested in these how much posted? Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 That's fine, Cannot do carrier on exhaust so are you OK to Collect, if so let me know and I will PM etc. g60knight said: hi buddy will take: 1 Exhaust Sys cat backwards Powerflow £40.00 1 Throttle Body VR6 MK3 3 pin ODB1 £20.00 1 Bonnet insulation after market waffle pattern £15.00 thks Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 I have some new waffle type foam as images to cut your own, but its a bit bulky so post maybe pricey, just let me know and I will PM etc Rado87 said: I’m would like the bonnet insulation (posted) if it’s in good condition/new. Same as above, can’t see the pics?? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 OK, Got good inner one too if you need them let me know and i will then PM etc. branty said: I would like both left and right outer slot seals please posted, 20 each Cheers Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 5, 2017 Thanks, I will PM you later on, but would be collect only if the Exhaust is still available Next project is a 205 GTI (corrado nearly finished) dan said: Hi mate, I'll take 2 Door end bungs £4.00 pair 1 Rear brake equalizer spring £1.00 1 Tailgate loom rubber @£2.00 10 Body OE aperture seals 40mm* £10 for the lot 1 RH Rainwater scuttle cover no clips £5.00 1 Fan blower motor working £5.00 1 Rear brake equalizer bolt socket head domed £1.00 Let me know what you need to post! Would also like 2nd dibbs on the Powerflow exhaust system, I was actually looking about one of these at the weekend. Thanks P.S. whats your new project? Quote Share this post Link to post Share on other sites
g60knight 0 Posted December 5, 2017 GrahamV said: That's fine, Cannot do carrier on exhaust so are you OK to Collect, if so let me know and I will PM etc. yes can collect it all buddy Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 7, 2017 List of parts now updated with remaining items and photos Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 8, 2017 Additional parts added & remaining parts updated. Quote Share this post Link to post Share on other sites
elliott 10 Posted December 8, 2017 Interested in the passenger door bump strip if new for a later car and also the light switch if it's for the same late style interior. Thanks. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 9, 2017 Left Door Bump strips are later type and new, also have a complete later left side of freshly textured matching set all as listed. Just confirm which & if head or fogs lamp switch required and will PM you details elliott said: Interested in the passenger door bump strip if new for a later car and also the light switch if it's for the same late style interior. Thanks. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
elliott 10 Posted December 9, 2017 Ok thanks, textured? I'm not sure now so will need to look. Also it's the main light switch, thanks again. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 9, 2017 Will photograph new and also textured set and update list with photos later today all being well elliott said: Ok thanks, textured? I'm not sure now so will need to look. Also it's the main light switch, thanks again. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
elliott 10 Posted December 9, 2017 Thanks, I'll go take a look. All strips have been replaced with heritage items except the passengers door which is unavailable. No one but me would notice but I'm a bit OCD about it. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 9, 2017 The 2 New Passenger door strips I have available were recently bought from heritage classic parts so should be correct finish. Will photo later elliott said: Thanks, I'll go take a look. All strips have been replaced with heritage items except the passengers door which is unavailable. No one but me would notice but I'm a bit OCD about it. Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 9, 2017 Post #1 updated with latest images, all apart from new Left Hand ones, will photo Monday elsewhere GrahamV said: The 2 New Passenger door strips I have available were recently bought from heritage classic parts so should be correct finish. Will photo later Quote Share this post Link to post Share on other sites
GrahamV 10 Posted December 11, 2017 Hi Now Updated with more bump strip photos Quote Share this post Link to post Share on other sites
elliott 10 Posted December 12, 2017 GrahamV said: Hi Now Updated with more bump strip photosThanks, interested in the heritage one please. I'll send pm Do you have the part number on it by any chance? Sent from my TA-1024 using Tapatalk Quote Share this post Link to post Share on other sites
