thesingh 0 Posted January 17, 2018 My Heater matrix is currently being bypassed as its no longer working. At the moment, I am unable to find anyone who is willing to take on the job of replacing it (based in South London). Has anyone got any ideas for any external heating solutions? I purchased a heater that uses the cigarette port, but that was terrible. Unable to find a battery powered heater. Anyone got any ideas whiles I find someone to fix it? Quote Share this post Link to post Share on other sites
Dogma 10 Posted January 17, 2018 thesingh said: My Heater matrix is currently being bypassed as its no longer working. At the moment, I am unable to find anyone who is willing to take on the job of replacing it (based in South London). Has anyone got any ideas for any external heating solutions? I purchased a heater that uses the cigarette port, but that was terrible. Unable to find a battery powered heater. Anyone got any ideas whiles I find someone to fix it? I know a top man he replaced mine did a cracking job, but he's in North Hampshire. Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 17, 2018 Send me some details, it wont hurt to enquire. Quote Share this post Link to post Share on other sites
Dogma 10 Posted January 17, 2018 thesingh said: Send me some details, it wont hurt to enquire.Sure I will give him a call just to make sure he's ok with me passing on details...standby ☺ Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 17, 2018 Dogma said: Sure I will give him a call just to make sure he's ok with me passing on details...standby ☺ Sent from my SM-N9005 using Tapatalk Thanks How much did he charge for the job? Quote Share this post Link to post Share on other sites
Dogma 10 Posted January 17, 2018 thesingh said: Thanks How much did he charge for the job? Very good question, which I can't remember the answer for mate. I'm in training at, so will call him at lunch. If I remember right I think it took about 4 hours. Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
Dogma 10 Posted January 17, 2018 (edited) thesingh said: Thanks How much did he charge for the job? Sorry for the bad news he said he's far to busy to take that on atm. Sent from my SM-N9005 using Tapatalk Edited January 18, 2018 by Dogma Quote Share this post Link to post Share on other sites
thesingh 0 Posted January 18, 2018 No problems, has anyone tried anything else to get heat in the car? Quote Share this post Link to post Share on other sites
Geeba 0 Posted January 18, 2018 DIY the matrix... take your time, plenty of pictures and label stuff up.. its just awkward and time consuming... soak the nut connections in the bulkhead with oil a few days prior as they will be rusty, follow one of the online guides, allow a weekend. Quote Share this post Link to post Share on other sites
Dogma 10 Posted January 19, 2018 (edited) thesingh said: Thanks How much did he charge for the job? Hi Try Grantleys tel 01256333777 in Basingstoke VW and Audi specialists. They are very good, but not be the chepest ... Sent from my SM-N9005 using Tapatalk Edited January 19, 2018 by Dogma Quote Share this post Link to post Share on other sites
a_riot 0 Posted January 20, 2018 thesingh said: No problems, has anyone tried anything else to get heat in the car? Are you certain its the heater core? You can also lose heat and AC when the foam backing on the hot/cold air flap disintegrates and falls off, usually shooting pieces of it at you through the vents. There are 3 holes that get uncovered once the foam falls off that allows hot and cold air to mix, so you get neither, just luke warm air. I think you still have to pull the dash to fix it, but thought I should mention it as the last thing you want to do is replace the heater core, put it all back together and still have no heat. Quote Share this post Link to post Share on other sites
Cressa 45 Posted January 20, 2018 Always worth recovering the flaps whilst the dash apart doing the heater matrix. Good suggestion Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 20, 2018 Agree - if you've got far enough into the job to be in a position to remove the matrix, split open the heater box while you're there and inspect all the flaps and seals and replace if needed - it's not a job you want to do twice. Watch out for those pesky little metal clips holding everything together. Also check the condition of the control cables and that they move freely - it's also possible to get the unit out and keep the control cables attached if you don't want to disconnect them in the car. Quote Share this post Link to post Share on other sites
