skid 1 Posted February 6, 2018 I occasional get what feels like a lose of fuel or misfire problem. Did a Vag com on the car and got this code : 00537 - Lambda (Oxygen Sensor) Regulation 11-10 - Control Limit Not Reached - Intermittent Readiness: N/A Can anyone shed any light on this as Ross tech has no explanation for this. Quote Share this post Link to post Share on other sites
Dox 31 Posted February 7, 2018 I occasional get what feels like a lose of fuel or misfire problem. Did a Vag com on the car and got this code : 00537 - Lambda (Oxygen Sensor) Regulation 11-10 - Control Limit Not Reached - Intermittent Readiness: N/A Can anyone shed any light on this as Ross tech has no explanation for this. Googled the code and this came up. http://wiki.ross-tech.com/wiki/index.php/00537 One of my cars used to lose power on left turns on a quarter tank or less, the pump mounts inside the swirl pot inside the tank had disintegrated allowing the pump to suck in air Quote Share this post Link to post Share on other sites
skid 1 Posted February 7, 2018 Thanks Dox, as stated Ross tech does not come up with: 11-10 - Control Limit Not Reached - Intermittent Readiness: N/A It has upper and lower limits but not that. My car had a full tank and it still did it so def not that! Quote Share this post Link to post Share on other sites
skid 1 Posted February 9, 2018 No other thoughts on this guy's? Quote Share this post Link to post Share on other sites
fendervg 33 Posted February 9, 2018 Check for air leaks in the intake and vacuum system and the PCV valve Quote Share this post Link to post Share on other sites
